Continental GT 2004 issues
Old Aug 6, 2019 | 05:57 AM
tomas valavicius's Avatar
tomas valavicius is infamous around these parts
Hi guys,
Guessing both egt sensors needs to be changed? Or it could be more more to it? How hard is to replace egt sensors? anyone experienced similar issues? No lights on dashboard. Would faulty egt sensor damage turbos?
Old Aug 6, 2019 | 07:09 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Try starting over and delete all the trouble codes. Many little things over time can set pending codes, no check engine light.
Often the old exhaust temperature sensors which are brown eventually fail. The new style apparently an improved design are black. Search Flying Spares for replacement parts.
In summary, yes under high boost and high exhaust temperature a faulty exhaust temperature sensor can be detrimental. Their job is to monitor exhaust temperature and to save the engine when excessive exhaust temperatures occur.
Your fuel trims are off. That would indicate an upstream problem. Vacuum leaks on the early Bentley as a 2004 need evaluation. Worth doing a smoke test on the vehicle.
Old Aug 7, 2019 | 12:22 AM
joc44's Avatar
joc44 is infamous around these partsjoc44 is infamous around these parts
With out this tool it's next to impossable
Old Aug 7, 2019 | 10:57 AM
Yoghurtshotgun's Avatar
Yoghurtshotgun is infamous around these parts
Check these pipes they have recently gone on mine causing all sorts of problems
Old Oct 28, 2023 | 02:08 PM
tteplitzmd's Avatar
5 Year Member
tteplitzmd is infamous around these parts
Tool
My independent shop borrowed the tool from the local Bentley dealer, who reluctantly loaned it.
sphinz
Oct 14, 2010 05:08 AM
cooperlee
Lamborghini
17
Jun 18, 2010 09:17 AM
PorschePhd
Jun 1, 2006 09:05 PM
