AC air distribution strange after flap motors repair
Old Aug 17, 2019 | 11:40 PM
dskippy888's Avatar
dskippy888 is infamous around these parts
After the mechanic replaced my flap motors, the AC is much louder now. I’ve set my AC on auto as I normally do, I hear the blower going at high speed and indeed the screen indicates the blower is in high but not much air comes from the main centre and side vents - almost as if the air is “stuck behind the dash”. Instead I feel the air from that black grill atop the middle of the dash is stronger than before. When I shut the car off I hear a lot of noise behind the dash almost as if tons of pressure is being released. Any thoughts? Mechanic said it’s normal but it’s certainly NOT normal as it never did this before.
Old Aug 18, 2019 | 02:03 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
To check each flap in the AC system is through vcds. Going to the air conditioning address and selecting the output test will test each individual flap for proper function. The Ross Tech vcds cable can be bought relatively inexpensively and functions on a Windows 7 or later laptop. Having this tool in hand is a good double check.
Old Aug 18, 2019 | 07:23 PM
dskippy888's Avatar
Thanks again! Will get one of these asap (but I'm pretty sure my mechanic had one, just didn't bother to hook it up). I'm assuming there's a function to do a 'reset' of the max/min values of all flaps? seems I will need to give very specific instructions to the mechanic.
Old Aug 19, 2019 | 07:31 AM
5 Year Member
Yes indeed the technician should do the adaptation. Inorder for the new motor to know where open and close positions of all the flaps this procedure must be implemented. Another good reason to get the Ross vcds cable. Hope you get this sorted out soon!
Old Aug 30, 2019 | 12:52 PM
MrVette's Avatar
MrVette is infamous around these parts
Definitely not installed correctly. When you push the manual buttons to change where the air comes from does that seem to work to direct the flow to the correct vents?
Not sure about your car but on my car to get recirc air is a manual function. Make sure to try that as well. Recirc has its on activator flap valve and that's the one that often goes bad.
Old Aug 31, 2019 | 06:46 AM
nguyennhatquang's Avatar
nguyennhatquang has a spectacular aura aboutnguyennhatquang has a spectacular aura about
my car has the Recirculation flap issue also and it did the same thing as you..
I'm on the way to change it but I don't know what is the part no I should Order.. and where is that motor...
does it easy to change or need disassembly the whole DASH?
Old Aug 31, 2019 | 03:07 PM
MrVette's Avatar
I got into this a few years back. If you search for a thread entitled "AC takes a long time to finally produce cool air. Also getting water in gas box." that was started on 8-25-15 You will find photos of the part and the part number. Also lots of discussion and info about AC issues in the dash.
The main flap and recirc flap have the same motor and Bentley recommends they be replaced together.
Although the shop manual says to remove the entire dash to get at the parts I found some later instructions that call for going through the cowl and accessing the parts from behind. I gave those instructions to the VW dealership where I had the work done.
Old Aug 31, 2019 | 03:38 PM
5 Year Member
Ac takes a long time to finally produce cool air. Also getting water in gas box when - 6SpeedOnline - Porsche Forum and Luxury Car Resource https://www.6speedonline.com/forums/...-box-when.html
Good info!!
Old Sep 3, 2019 | 03:39 PM
5 Year Member
MrVette thank you for the attached information. Today was hot and humid. The air conditioning was crisper and cooler by using the suggested method of turning on recirculation. Turned recirculation off and the hot humid air could be felt, mingling with the air conditioned air. Now I have a better appreciation of the air conditioning at least in my BGT.👍😎
mziegler38
Jun 18, 2017 06:04 PM
Ktw
Mar 10, 2017 04:32 PM
cblanco
Oct 25, 2016 03:56 PM
SMKaz
Sep 22, 2015 05:12 PM
Katera
Mar 1, 2012 01:18 PM
