2006, 2007 or 2008 CGT?
Old Oct 12, 2019 | 02:49 PM
Randy V's Avatar
5 Year Member
Randy V is infamous around these parts
Question for the Bentley brain trust -
I'm about a month away from purchasing a Bentley Continental GT Speed hard top.
Is there any significant differences between these three model years, such as more infotainment system options or other things that make the 2008 much more desirable vs the 2006 or 2007?
Appreciate your insights!
Thanks.
Old Oct 12, 2019 | 04:29 PM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Thanks.
Hello Randy V and welcome.
Do you plan on making any changes to the car like the Ben HUR and radio? If your into XM radio I would say get an 08 because they added XM to the cars in 07. That way you don’t have to worry about running your own antenna. And with the 08 you don’t have to worry about the vacuum leak the 06 and some 07 have.
Old Oct 12, 2019 | 05:47 PM
Randy V's Avatar
5 Year Member
Thanks, guys. Ah yes - the vacuum issues being eliminated in 08 is compelling reason to go with that model year or newer.
What is the Ben Hur issue about? Personally not interested in satellite radio, but the ability to stream audio is important.
Anything else?
Old Oct 12, 2019 | 06:10 PM
Johnny Hotspur GT's Avatar
Administrator
Hi Randy,
Do realize that the vacuum leak problems that occurred in the 03-07 had to do with the lines over the transmission in the GT's, but do realize that they all, past and 07 plus (newer) all suffer from the other vacuum lines along the firewall having the same leaking problems as the transmission mounted lines, SO, do be sure to make sure said firewall lines are good, via smoke test, prior to purchase.
Johnny
Old Oct 12, 2019 | 07:16 PM
Veteran: Navy
Anything else?
Well in that case just search for Bluetooth in here as some have fit a adapter that plugs into the cigarette lighter and you find a station on the radio and it streams that way. They seem to love it.
Old Oct 12, 2019 | 07:47 PM
Veteran: Navy
Originally Posted by Rico.Adams
But one still won't have most of the radio stations & most importantly satnav, the stock system is to old & out of date, dont you think ...
Yea but he said he don’t really care about XM/Sirius radio...just streaming. So he has more options now. I don’t think I’ve ever used my navigation in the car. I always use my phone and she speaks through the speakers while I’m streaming my music. I’m a tech guy so I wanted all of that plus more 😂 . Some stuff I use, some I don’t but I want it just in case lol. I’m just waiting on mirroring without the cords like you can do in the house and I’ll be all set.
Old Oct 12, 2019 | 08:00 PM
Veteran: Navy
Ok ...
As you I'm a tech guy wants all the gadgets, I can show how to do mirroring workout a lead I'll email it to you ...
Let me see what your talking about...🤔...I had an idea to use an old fire stick but never got around to it.
Old Oct 12, 2019 | 08:08 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
I may be wrong but I thought the GT Speed started in 2008.
Old Oct 12, 2019 | 08:32 PM
Administrator
Yes, I thought the same as to the "SPEED" being mentioned, but I took it as Randy asking what the differences were between 2006-2008 of the Bentley GT in general, my main concern would still be any vacuum lines leaking as mentioned.
Johnny
Old Oct 12, 2019 | 09:40 PM
Administrator
From 2004 to 2007 these cars where the same spec engineering wise
From 2007 to 2011 again the same & so on
The speed spec was introduced in 2008 as the 2 videos I posted
No one problem is a significant to any one model to another
The cars all come down to age, mileage & maintenance, in other words if it's going to break
it will or you may have care free driving for years...
Agreed 100%, so be vigilant in your inspection of the vehicle and its known issues.
Old Oct 13, 2019 | 12:18 PM
sam08861's Avatar
5 Year Member
sam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud of
Didn't view the videos to see if this was mentioned, but in addition to the obvious differences for the front bumper, I believe the 08+ have a more upright grille.
You can see it in the preview stills in the 2 youtube clips above. The older model is more curved and smooth to the hood and the newer one is more vertical, squared off. If you look at the body seams where the headlights meet, you can see the larger triangular shape just above the headlights, behind the top corners of the grill, on the newer model.
I have the 1st gen, but the newer 08+ looks better to me. (a bit more presence)
edit, also 08 speed has the newer style steering wheel also, which is another plus in my book.
Old Oct 13, 2019 | 02:33 PM
sam08861's Avatar
5 Year Member
I did the install on my current 06 GT.
As to the amount of work...
For someone with a bit of experience with wiring up stereos, with all the parts, instructions laid out, I think one could get this done over a weekend, spending maybe 5-6 hrs a day, accounting for mental breaks, etc.
1st day configuring firmware/software and getting everything working on a bench, 2nd day installing in car, running wires. If one knows their way around the BCGT as far as removing the head unit, back seat, center console, etc., day 2 could easily be cut down to 2-3 hours.
I had to learn how to do a lot of the stuff I've documented how to do in the instructions, so took me longer, not having that clearly spelled out as it is in the document, or in one place. I had to search the web, learn by trial and error what works, etc. Also got a lot of help and clarifications from lilo1980, who was very generous with his time.
Tried to document all of that to make it much easier for the next guy, with specific part #s, software steps, etc. Should shave 30-40 hrs of research/learning.
Biggest overall time gap was waiting on parts from overseas, some of which take ~30 days, followed by all the prep work to get the SW working, drivers installed, etc. Most of day 1 time is waiting for downloads, installs, firmware updates, etc. as opposed to actual work.
Additional time on top of the install times, I'd say 2-3 hours to carefully get all the parts ordered + another 2 to 4 hours of reading up/rereading/researching things/figuring out how to route wires, etc. to understand everything before tackling the job.
Old Oct 13, 2019 | 03:19 PM
sam08861's Avatar
5 Year Member
Thanks Rico and good luck with the firmware upgrade.
Old Oct 16, 2019 | 09:26 PM
Randy V's Avatar
5 Year Member
Thanks guys - your insights are invaluable.
That said... see my new - and hopefully last - thread about the car I'm about to purchase to join the ranks of you lucky bastids.
Old Oct 17, 2019 | 08:09 PM
Randy V's Avatar
5 Year Member
Hi RV ... Hope its not your las thread on the forum, congratulations welcome to Bentley ...
Not hardly Rico - you stuck with me now - lol.
Love this group. Have been involved in Porsche, several BMW models and Lexus forums - you lads here are a cut above.
