Power steering issue?
Old Nov 8, 2019 | 07:09 AM
rooks's Avatar
rooks is infamous around these parts
With my 05 CGT, as soon as I put some throttle the steering becomes heavy, as if the power steering is only working partially. At idle all is fine. Oil is clean, level OK. Anybody?
Old Nov 8, 2019 | 08:33 AM
nguyennhatquang's Avatar
nguyennhatquang has a spectacular aura aboutnguyennhatquang has a spectacular aura about
I think your power steering pump got bad..
Old Nov 8, 2019 | 01:07 PM
rooks's Avatar
Originally Posted by Rico.Adams
Hello Rooks ...
These car are fitted with a system called Servotronic Power Steering, this means with the engine on & at idle the s/wheel would feel very light & can turn without any effort & at low speeds, once driving a higher speeds the steering automatically get heavy to hold the road.
To my knowledge it seems like the system has failed & needs resetting (ross tech) if the main box has failed the steering would feel heavy even at idle ...
Hi Rico
That makes sense, the symptoms are exactly as you describe.
Is it possible to do the reset with a VAG V-Checker? Or can it be a failed Controle Module?
It works totally fine at idle/low rpms.
Old Nov 11, 2019 | 06:44 AM
rooks's Avatar
Yes I would do a reset & take it from there, with any luck it should be fine, let me know ...
I disconnected and connected the batteries, no change.
Steering light at idle/parking/reverse, stiff at acceleration like before.
44-Steering Assist gives "comm error" with v-checker. Module/Relay malfunctioning?
ross_macdonald
Cayenne 955/957
Apr 1, 2014 08:33 PM
ek1
Bentley
Sep 21, 2013 06:43 PM
Matrix
Cayenne 955/957
Oct 22, 2010 08:45 PM
