Battery Tender
Old Nov 26, 2019 | 04:45 PM
flaav8r's Avatar
5 Year Member
flaav8r is infamous around these parts
Battery Tender
I keep a battery tender on the main battery via the "cigarette lighter" port in the trunk/boot whenever I'm not driving the car. Does this also keep the starter battery charged or do I need a separate tender for that one?
Old Nov 26, 2019 | 05:14 PM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
No .
You only need to keep the LHS ( as you stand behind ) charged .
This is the one that decays as it runs the alarm and fires up all the ECU s when you unlock the car .
The RHS starter just spins the starter motor only nothing else .Its my understanding
Infact without various ECU , relays and other electrotwackery powered up correctly from the RHS the door will not be opened so to speak for the little LHS to do its job .
There may be a connection from the trunk socket on the LHS to the little starter bat ,but I doubt it because it’s irrelevant as the LHS power can be grabbed temporarily using the key anti-clockwise anyhow .
Since there’s no parasitic ( alarm , radio codes , Seat memory codes etc ) on the little RHS starter bat .It can last a long time when the car is parked up .
The LHS needs tendering ........many spurious errors and lights occur if it’s voltage drops .
The cigarette lighter IN will be the LHS bat only .
There a feeling the OEM plug for the charger does both but as said I doubt it L
Hard wire a pig tail to the LHS bat ....that’s what I do and the max parked up time has been 3 months on a bat tender with no ill effects ....just fired straight up .No dash warning lights or chimes etc .
Old Nov 27, 2019 | 11:23 AM
GT3 Chuck's Avatar
Administrator
Yogurt shotgun. Post your item in the marketplace...or use pm. Thanks
topofthemorning
Jun 20, 2020 11:09 PM
macksamus
Dec 13, 2016 03:47 PM
jamie
Nov 1, 2004 03:33 AM
rspiteri
May 12, 2004 01:27 AM
