Trunk not open because KESSY module is dead
Old Mar 3, 2023 | 02:47 PM
Bamaboy92's Avatar
Bamaboy92 is infamous around these parts
Hello Sam,
Did you not read my prior post, this is not good information, if you notice the person in the video never actually removed the tail light, doing so would cause damage possibly to the lens, but 100% to the retaining studs that are seated in the tail light itself.
Please, if you are ever not able to access your trunk because of dead batteries, then unlock the door with the physical key, and apply power as I stated above through the C/L or tapping into the fuse box at the lower dash area, tap into a 20 amp or 30 amp body fuse and give it some time to charge up, or give the trunk release button a quick try, but never try to start the engine this way, also one could unlock the door as stated with the key blade and pop the hood to access power connection at the firewall.
Johnny
which fuse do you use to do this also what tool do you use
Old Mar 3, 2023 | 08:07 PM
Bamaboy92's Avatar
Originally Posted by Bohemicus_cz
Hi all, thank you for help... I have new information....KESSY is OK, problem is in Central Control Module for Central Convenience (J393), not communicate. Comfort modul is bad, then not reading key, not open trunk, not open gas cap, not open windows. Battery both is OK. Servis man must remove right back seat...I have Mulliner 4 set, and after then open trunk and then next repair. :-)
how did you get the boot or trunk open?
Old Apr 2, 2023 | 01:45 AM
tmobileguy's Avatar
tmobileguy is infamous around these parts
Originally Posted by Samhain
You can trickle charge the batteries through the cigarette lighter (need the proper adapter of course). That should give you enough juice to pop the trunk.
I'm guessing you have never tried this because it doesn't work. As usual, your advice is awful and not helpful.
Old Apr 2, 2023 | 01:46 AM
tmobileguy's Avatar
Good job posting some really bad information.
As Johnny already alluded to, your advice is terrible so please stop posting bad advice.
N91K
Jun 25, 2019 04:25 AM
robkat
Nov 21, 2017 12:03 PM
jeffreym
Bentley
Dec 16, 2013 11:10 AM
rwilliamtaylor
Oct 19, 2008 01:21 PM
Turbochris
Jan 1, 2008 06:26 PM
