Headlight Warning - Flashing Headlight
Old Dec 12, 2019 | 12:46 PM
StraightShooter's Avatar
StraightShooter is infamous around these parts
Any thoughts on the cause: I have a 2008 Bentley Continental GTC. Last night a headlight warning was displayed along with the warning icon for headlights. My left headlight will turn on, then off, then flash for a few seconds, then go completely off. I have turned the vehicle on and off, changed the headlights from automatic to constant, etc. Nothing changes - I still get the flashing left headlight until it completely turns off. I can understand the bulb going bad and needing to be replaced, but I know the bulb works because it flashes on and off before turning completely off. As a side note, I had the car washed the same morning that this started happening, but I assume that's just a coincidence.
Old Dec 12, 2019 | 02:42 PM
AJ1's Avatar
AJ1
5 Year Member
AJ1 is infamous around these parts
Any link to the left indicator, try switching around with that while headlights on. Also hazards. Just a thought.
Old Dec 12, 2019 | 03:06 PM
ret09gt's Avatar
5 Year Member
ret09gt is infamous around these parts
You have a bad bulb. My 09 did the same thing and it was the bulb. You can change the drivers side without much difficulty. You have to work with one hand. Be careful to have the bulb seated before replacing the spring tabs or you will bend them. It is best to use a small piece of double side tape on the bulb base and that will keep the bulb up against the mounting freeing your hand to secure the tabs. I bought my bulbs from Audi.
You have to rotate the silver cap and pull out. Squeeze the two wire tabs together to release the bulb.
Jetman 7
Nov 1, 2022 03:38 PM
ciaka
Cayenne
Apr 29, 2018 09:38 PM
ek9max
Oct 5, 2011 05:38 PM
Hedonistic
Aug 6, 2010 11:05 PM
John Romano
Jul 5, 2010 12:25 PM
