Bentley Continental GT 2005 - Rad fan issue
Old Dec 4, 2020 | 09:28 AM
  #31
sunt_4_you's Avatar
sunt_4_you is infamous around these parts
Hy I have a problem with my Bentley Continental flying Spur 2005 LHD
the car was fine the Car stands for 2 months
then I noticed the both fans don’t work
I change them I check all the fuse all ok
but then I open the fuse box under the bonnet was water there then I clean the water but still
don’t works I find a relay nr “100” under the bonnet on the fuse box I start the car with a/c on
I open the cover for relay I press manual
the both fans start to work until full speed then cut off
i plug to obd but nothing comes up
also my engine lights come on
but says lambda sensors
also the car charging until 13volts
so I don’t know know wat is the issue please help
Old Dec 4, 2020 | 09:49 AM
  #32
Littlj01's Avatar
Littlj01 is infamous around these parts
Sunt_4_you, I would make sure that the fuse box is completely dry and the look underneath. This might take a good long time to dry. Until dry you might get a lot of strange errors. I know I did. When dry you need to make that fuse box area water tight.
Old Dec 4, 2020 | 09:50 AM
  #33
Littlj01's Avatar
Sorry Loom underneath. My right hand drive can had the loom go into the passenger foot well above the light for the feet.
Old Dec 4, 2020 | 10:04 AM
  #34
sunt_4_you's Avatar
Yes Was some water under the passenger foot but now is dry
Before when I plus the OBD was coming fan 1 and 2 circuit low ,, now doesn’t come
I have the engine light on comes On OBD BANK 1,2 lambda sensors
I don’t know what to do
Old Dec 5, 2020 | 10:34 AM
  #35
sunt_4_you's Avatar
yes was weet
but I find the problem was
on the fuse box under the bonnet
was a wire from relay 167 to 100 was not good I fix now works both radiator fans and no more engine light on the dash
i put all back now I putt some silicone on the fuse box also some double tape just in case water don’t go there
thanks anyway for your help
Old Dec 5, 2020 | 10:38 AM
  #36
Johnny Hotspur GT's Avatar
Administrator
Thank you so much for documenting the issue @sunt_4_you !
Old Dec 5, 2020 | 10:54 AM
  #37
sunt_4_you's Avatar
Johnny Hotspur GT
no worries thanks you very much
I live in london uk
now I have both radiator fans because I was replaced them
if someone need them I pay £180
I just want my money back
Old Dec 5, 2020 | 11:02 AM
  #38
sunt_4_you's Avatar
this was the issue they have a wire connect to them
Last edited by Johnny Hotspur GT; Dec 5, 2020 at 12:42 PM. Reason: Fix QUOTE again, please stop typing in the quoted section with your reply.
Old Jun 9, 2023 | 05:19 AM
  #39
Mitchy1971's Avatar
Mitchy1971 is infamous around these parts
Originally Posted by sunt_4_you
Johnny Hotspur GT
I live in london uk
Do you have the fans???
temi
Bentley
10
Feb 5, 2022 11:29 AM
Tobanla21
Bentley
31
Sep 28, 2019 01:20 AM
hammond
Bentley
Jun 8, 2017 10:25 AM
haggu
Bentley
10
Oct 20, 2011 03:17 PM
Jackedwards
Bentley
Feb 21, 2011 08:54 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
