Fluid Types and Capacities?
Old Mar 1, 2020 | 05:55 PM
Randy V's Avatar
5 Year Member
Randy V is infamous around these parts
Unlike most car Owner Manuals, the CGT manual does not have a listing of fluid types and capacities.
Is that info available somewhere on line? I'm specifically looking to know what type of fluid to add to my power steering reservoir. It is currently showing in the MIN area of the dip stick on the cap.
Also, is fluid level checked with the engine running or switched off?
Much thanks.
Old Mar 1, 2020 | 10:19 PM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
Should have two manuals in the book pack .
The leather bound owners ....how to operate, switches etc and a thinner technical book with the fuse diagrams , changing spare , bulbs and fluids type / vol etc .
I,ll have a look in the morning and take a pic of the relevant page .iirc it’s a special green hydraulic fluid called CHF - Central Hydraulic Fluid .
That’s why the cap is green on the reservoir btw .
, NOT the regular red PAS .
Mine started to need to topping up say a bit every 6 months ......the PAS pipes corrode .Theres one in particular accessed under a wheel well, the side with the reservoir that goes first .Three in all , best to get all three done while in .Unfortunately one usually requires heat to loosen off , 50 % loosen the other half do not and necessities removal of the rack .Mine came off ok + some heat on the worst one of the three .
If the bad weepy one is real stuck even with the rack out on the bench it’s easy to knacker the threads ,or snap off the alloy nipple and basically bust the rack beyond repair.
So find a tech that’s done a few and knows the work arounds , or swallow a big “ brave pill “ and have a go yourself ?
Old Mar 2, 2020 | 05:12 AM
Interesting jump start connects as well ,
Old Mar 4, 2020 | 02:31 PM
Randy V's Avatar
5 Year Member
Greatly appreciated John! I'm guessing I can't find that at a regular auto parts store?
I recently bought the car from the original owner who was on death's door. It was sold for him by a friend.
Due to the circumstances I was unable to acquire any other documentation besides the owner manual. I was lucky to get that plus the extra full function key.
Old Mar 4, 2020 | 06:03 PM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
You can buy all the fluids at any auto store. I bought the CHF from either Advance or Orielly’s for my BMW.
Old Mar 4, 2020 | 08:06 PM
H-M3's Avatar
H-M3 is infamous around these parts
Not to jack this thread but can anyone advice what oil brand is suitable for gt? Just because they say Mobil 1 does that mean you should only use that?
ta
Old Mar 5, 2020 | 02:38 AM
ta
Ah and oil thread about erupt !
I take mine ( uk reg ) to a Bentley / RR specialist for its MOT and effectively throw in its annual oil change as a sort of lost leader for them .
They make a point of the Mobile 0W40W .
I have a piece of paper annually in the file ( techs invoice) with the correct spec .....woefully hopefully one day from a residual POV it my help sell it ??
I know it’s expensive but it’s the 0 bit the low temp cold start that’s important on one hand to lub up the turbo bearings and others and the 40 for when it’s gets hot .
It’s pretty tight in there and the heat dissipation management looks critical.
I know I cruise around 2000 rpm with the odd foray north of 3500 , so my car I hope gets an easy life .
Having said all this you never hear of actual engine + turbo trouble with theses and there will be some running round with different oil , super extended change times, and as thrashed as you can get .
Would have thought the most vulnerable parts are the twin turbos , there bearings will fry first if the oil is not up to the job .
Old Mar 5, 2020 | 02:42 AM
H-M3's Avatar
makes sense I guess. Opie are doing special at present 10L for £85. Someone on another forum said... just because Beckham drinks Pepsi it does not mean it’s the best fizzi pop. Lol
Old Mar 5, 2020 | 08:43 AM
Randy V's Avatar
5 Year Member
Thanks TJ - off to Auto Zone!
Old Mar 5, 2020 | 03:23 PM
Randy V's Avatar
5 Year Member
Picked up a quaint tin can of Pentosine at Auto Zone.
$30 vs $7.00 for the US stuff.
VGLNTE1
Jan 20, 2015 07:21 PM
Audi Junkie
Mar 29, 2013 10:36 PM
Hurdigurdiman
Feb 27, 2013 04:36 PM
intheflesh
Cayenne 955/957
10
Apr 14, 2012 05:46 PM
elduderino
Apr 25, 2005 04:18 PM
