Naim System Issue - System Starting.......but never does
Old May 2, 2020 | 05:10 PM
Neil Mason's Avatar
Neil Mason is infamous around these parts
Got a 2015 GT V8s with Naim Infotainment.
On start up message just hangs, showing system starting.....but doesn’t actually change or start. Worked sporadically but now not worked for nearly 3 weeks at all
The car is my dd, 20 miles each way to work
Was advised on other forums that this could be due to low LHS battery which was reading 11.7v when engine off
Changed battery in line with correct procedures( pretty sure) but still not getting the system running.
Any ideas or suggestions to what could cause this
Other than the option of settings and a bit of music, I’m due for new tyres and need to be able to use jack mode
Old May 2, 2020 | 07:24 PM
AJ1's Avatar
AJ1
5 Year Member
AJ1 is infamous around these parts
Hi again Neil, Ive been following your thread on fb and it was me who advised you of the battery change procedure and hooked you up here. You'll get help here for sure, there are some very knowledgeable and helpful owners.
Andy.
Old May 3, 2020 | 02:42 AM
Neil Mason's Avatar
Andy.
Thanks for the tip for here Andy. Reading through, they certainly know their stuff !
Old May 3, 2020 | 03:03 AM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
Old May 3, 2020 | 04:14 AM
Neil Mason's Avatar
Originally Posted by John Fiammetta
thanks John - not sure this is the same issue. The system doesn’t even start right now - it did intermittently at various stages of a journey
the screen shot of the actual unit sits like this then now and again restarts as if trying to reboot and you hear some whirring but never quite gets over the line
Message in the instrument panel sits showing this
it will connect to my phone but doesn’t send the sound over the speakers
Checked the 3 fuses and they are all intact
Old May 3, 2020 | 06:59 AM
pwc6t3's Avatar
pwc6t3 is infamous around these parts
My 2015 Speed with Naim has the same issue. It is a software problem and will need to be reloaded. Mine started doing it the exact same way you describe.
The only other option is to get a new infotainment unit, which is over 4000 and your unit as core deposit. If you do that, make sure you get a Naim loaded unit. A non Naim unit will not give you any sound at all.
Old May 3, 2020 | 08:58 AM
Neil Mason's Avatar
how do you go about getting it reloaded ? Is it something g you can do yourself ?
Old May 3, 2020 | 09:40 AM
pwc6t3's Avatar
That is not a DIY project. You have to take it to the Bentley dealer. Depending on the dealer they will likely try and convince you that they can't reload the software and will say you have to buy a whole new unit. This is a known problem, but still pretty rare, so they may not have the software update on hand, so you should call ahead to make sure. I live 6 hour round trip away from a dealer, that is why I haven't gone in to get mine updated yet.
bushrat
May 2, 2017 04:41 PM
jsimon77
Jul 31, 2015 11:59 AM
Vantaredoc
Mar 1, 2014 05:14 PM
Vlar
Feb 2, 2004 01:36 AM
