Air suspension Replacement DIY help
Old Sep 8, 2020 | 01:43 PM
shorttough's Avatar
shorttough is infamous around these parts
How do i bleed the air pressure from the newly shipped suspension. My car has sunk in the front and I’ve taken out the air strut out, but if you look at the size it’s bigger than the bad air strut. And there is barely any room to install the new part.
Old Sep 9, 2020 | 03:39 PM
shorttough's Avatar
One thing that I have read that you must never do is release the non-return valve on the air input connection to the strut.
would you please explain the above statement.
from what i understood, these are the screws i have to take out.
Old Sep 9, 2020 | 05:29 PM
shorttough's Avatar
So all i did was had jack mode on before i took the wheels off and mounted on a jack. The clearance i had was enough for it to just come off, i didn’t require to remove the anti roll link. So you’re saying i would need to remove it to install the newly charged air suspension?
2010panamera1
Sep 8, 2024 12:22 AM
shorttough
Bentley Vendor Classifieds
Sep 8, 2020 02:08 AM
VincentEmmanuel
Oct 30, 2017 04:58 PM
richard181
Bentley
Mar 18, 2017 05:36 AM
MichaelCS
Cayenne 955/957
Nov 16, 2015 08:53 PM
