07 Bentley GTC how to open trunk lid cover to change antenna
Old Sep 13, 2020 | 09:56 AM
Mzny100's Avatar
Mzny100 is infamous around these parts
I am having trouble with my 2007 Bentley GTC satellite radio connection. Getting only static. I have read a lot of these had issues and needed antenna replacement located in the trunk lid. How do I open the trunk lid ? I see one screw in the handle area. What is the correct way of popping this open? Thank you so much.
Old Sep 14, 2020 | 10:29 AM
Mzny100's Avatar
Interesting.... so once I take out the one screw how do I remove if disengage the clips? Did I just pull until they pop ? Here are pictures of the lid it self.
Old Nov 18, 2020 | 12:03 PM
Big Blue's Avatar
Big Blue is infamous around these parts
Ummm...
Interesting that you would think that the owner doesn't know what his boot/trunk lid liner looks like. The QUESTION is how to remove the carpet and the plastic components and in what order, so as to do the job properly but not damage the components.
Old Nov 20, 2020 | 04:05 AM
John R. Allen's Avatar
John R. Allen is infamous around these parts
Once you remove the handle...gently pry down the
showing behind the liner....
This might be what you are looking for....I only listen to SiriusXM satellite and have never used am/fm.
carpet piece/liner...The first picture you will see the clips that hold it in...
Clips that really hold!
lilo1980
Bentley
25
Mar 26, 2025 11:04 AM
Martin Perri
Bentley
29
Jul 4, 2024 06:01 PM
Stuart2004
Bentley
May 17, 2020 12:28 PM
John R. Allen
Bentley
May 6, 2020 03:25 AM
fredham1
Bentley
Sep 3, 2018 03:06 PM
