Airbag Light ON
Old Feb 2, 2021 | 03:58 AM
Pablen84's Avatar
Pablen84 is infamous around these parts
Airbag Light ON
Hola, hoy se ha encendido la luz del airbag en el GT Speed del 2008 y el coche no ha tenido ningún golpe. ¿Sabes cómo puedo solucionarlo? ¿Podría ser un cable suelto al que no es muy difícil acceder o debería enchufar la computadora?
¿Podría ser algo más serio?
Muchas gracias.
EDIT: Translation
Hi, the airbag light on the 2008 GT Speed ​​came on today and the car didn't have any bumps. Do you know how I can fix it? Could it be a loose cable that is not very difficult to access or should I plug in the computer?
Could it be something more serious?
Thank you very much.
Last edited by Johnny Hotspur GT; Feb 2, 2021 at 07:47 AM. Reason: Translate to English
Old Feb 2, 2021 | 07:51 AM
Johnny Hotspur GT's Avatar
Administrator
Hello @Pablen84 ,
Yes, a scan would be most helpful, as it will pinpoint which airbag is showing fault, most likely either the left or right knee airbag if anyone was working in either area, or the clockspring may have a fault on the steering wheel.
But let's see what the scan show so we know where to start.
Johnny
Old Feb 2, 2021 | 08:24 AM
Pablen84's Avatar
Hello @Pablen84 ,
Johnny
Thank You, I Will take the car to the garage and make It a scan. The car is at home, nobody is working on It but today my father took the car for a spin and the light goes on.
Old Feb 25, 2021 | 08:06 AM
Pablen84's Avatar
I took the car to the garage, they plugged the computer in and fail gone, but five minutes later It came again. So the mechanic told us to change the switch in the passenger´s side.
He said the piece is the same in VW, is It true?
I Know Bentley uses some pieces from VW but I don´t know If this piece too.
Next Wednesday He will change It. Cost here in Spain is 120€ the pice + 21% taxes + handwork.
Old Feb 25, 2021 | 09:00 AM
Administrator
Hello @Pablen84 ,
I take it that you are referring to the on/off switch for the passenger side front air bag, you should ask him what is the part number of the replacement part he is ordering, so you may cross reference it, may GT has the key style switch in the glove box, I see two different styles of the switch available, one with the key, and the other a push button, which do you have ?
PART NUMBER: 3D1919211A which is number 4 in the illustration as a key switch.
Whereas
PART NUMBER: 3W3919237 appears to be a push button switch, as shown as number 13 in the illustration.
Johnny
Old Feb 25, 2021 | 09:06 AM
Pablen84's Avatar
Thanks a lot
Old Feb 25, 2021 | 09:20 AM
Administrator
Originally Posted by Pablen84
Thanks a lot
Please let us know which style airbag switch you have when you find out.
And yes, the VW Pheaton switch does fix the Bentley.
Johnny
Old Feb 25, 2021 | 10:15 AM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
Same issue with Maserati passenger airbag switches. Alfa Romeo shared part. 25% of the cost.
FWIW I believe key switches are obligatory in Europe.
C
Old Feb 26, 2021 | 02:18 AM
Pablen84's Avatar
Originally Posted by CatmanV2
El mismo problema con los interruptores de las bolsas de aire del pasajero de Maserati. Alfa Romeo compartió parte. 25% del costo.
FWIW Creo que los interruptores de llave son obligatorios en Europa.
C
Correct, they are required in Spain. And is the key switch.
We will see If It works on Bentley.
Old Mar 3, 2021 | 09:23 AM
Pablen84's Avatar
Finally, I have It repaired, the piece is form Audi - Volkswagen.
the piece in the bill is called Airbag conmutator (3D1919211A). Total cost with taxes (21%) 183.38€
Number 4 in Johnny´s picture
Old Mar 3, 2021 | 09:52 AM
Administrator
Great !
And thank you for your follow-up.
Johnny
Old Sep 29, 2023 | 07:45 AM
ew1435489's Avatar
ew1435489 is infamous around these parts
He estado en tus zapatos, buscando una casa de apuestas confiable. No busque más allá del sitio https://apuestaes.tv/casas-apuestas/. Han reunido una lista completa de las mejores casas de apuestas, ofrecen información sobre la elección de sitios de apuestas deportivas y brindan reseñas concisas de varias plataformas. ¡Es un paraíso para los apostadores!
Old Sep 29, 2023 | 09:16 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Spam alert!
cjcam930
Aug 25, 2014 12:41 AM
3POINT8
Aug 22, 2014 05:35 PM
Diablo360
Apr 7, 2011 06:41 PM
