Bentley continental gt / gtc / flying spur - boot or fuel cap switch not working
Old Jul 22, 2021 | 08:36 AM
heathrow99's Avatar
heathrow99 is infamous around these parts
If your boot open and/or fuel cap open switch is not working , here is a simple fix.
It will be the circuit board in the drivers switch pack that is faulty. Pull up the switch pack, there are no screws holding it down, simple to lever up and out. Once switch pack is out, remove the screws at the base of the switch pack, gently lift off the cover and you will now see the pcb board (remove is slowly and gently pry it away from the white plastic switch cover, saves time when putting it back after, you disturb the switches otherwise.
You can clean the board with a good pcb cleaner and a toothbrush, you will probably see water ingress marks on it. This should get the switches working again. But if damaged badly, buy a VW Pheaton drivers window switch pack, swap the pcb boards they are exactly the same, and a fraction of the cost of a Bentley one.
I have now purchased a couple for keeping in my cupboard as spares whenever I need them. Pic of the ones I purchased, but any vw Pheaton one will work.
Old May 4, 2023 | 11:28 PM
jking702's Avatar
jking702 is infamous around these parts
Hi. I need to switch the board im the door panel control switch. Is this plug and play or do you have to do any soldering ?
Old May 5, 2023 | 12:52 AM
heathrow99's Avatar
very straight forward. simply swap and refit. nothing else required
Old Jan 12, 2024 | 03:18 AM
molafisoye's Avatar
molafisoye is infamous around these parts
Legend!
I registered on here just to say thank you!
Sirpopple
Bentley
26
Oct 26, 2024 04:01 PM
Bullsharks38
Bentley
Apr 27, 2021 09:18 PM
gwint2007
Bentley
44
Jul 23, 2020 05:35 PM
andygreenwood
Bentley
Apr 29, 2019 07:04 AM
Ellie
Bentley
Mar 30, 2018 09:06 AM
