Bentley-Best Options to Read Codes & Modify Systems
Old Aug 4, 2021 | 10:16 AM
DesotoJohn's Avatar
DesotoJohn is infamous around these parts
New owner of a 2014 FS and want to be able to read codes and make (simple) system changes. At present, the rear seat entertainment system is not responding and the backup camera stopped operating, last weekend. No mechanical issues, but not sure if batteries should be replaced to rule out any voltage anomalies. I replaced a damaged rear side window shade, so not afraid to tackle straight-forward dismantling tasks. Would like an idea of the problem, before car is taken to a shop. Any guidance would be greatly appreciated!
Old Aug 4, 2021 | 10:52 AM
Samhain's Avatar
Samhain is infamous around these parts
Old Aug 4, 2021 | 11:08 AM
DesotoJohn's Avatar
I appreciate the quick response!
I will go through the descriptions and may have a few questions on differences. Thanks, again!
Old Aug 4, 2021 | 11:30 AM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
The only differences are in the number of VINs you can register or if you want WiFi / USB.
It's a great piece of kit IMHO
This might be a better link to understand the options as it were
https://store.ross-tech.com/shop/cat/VCDS/
C
Old Aug 4, 2021 | 04:24 PM
DesotoJohn's Avatar
Thanks for the links and comments - a few questions?
I went through the website info and had questions about:
-considering an enthusiast kit, what is the pros/cons to the wireless option?
-I currently have a Bentley, Audi, BMW, Jaguar, Land Rover & Lincoln. Is this only applicable to the Bentley & Audi? If yes, then any experience with the 3 limitation being an issue?
I will purchase an enthusiast kit, but trying to gauge options without any prior experience. Again, the help is appreciated!
Old Aug 4, 2021 | 11:29 PM
CatmanV2's Avatar
5 Year Member
Personally I'm more than happy with the wired option. Really can't be faffing around changing the wifi networks of whatever device I want to use to do my diagnostics and the chips in these devices never seem that great. Why they just don't use bluetooth (which is pretty perfectly suited) is a little beyond me.
I expect these will only work well for the Bentley and Audi. Certainly never had an issue with the limitations, but I only have the Continental
C
Old Aug 5, 2021 | 03:04 AM
CatmanV2's Avatar
5 Year Member
Originally Posted by Dark Green
I use VW's ODIS tool for diagnostics, and that does indeed use Bluetooth for comms twixt OBD Dongle and Laptop.
Seems far more sensible to me. ODIS is quite costly, though?
C
Old Aug 5, 2021 | 04:23 AM
CatmanV2's Avatar
5 Year Member
£50 for the hardware and software combo, but bearing in mind the sensibilities of the moderators to discussions of such things, I'll simply say that the purveyor might ordinarily be expected to be seen in the company of two score of thieves IYSWIM.
Given the origin, the software runs inside a very tightly controlled sandbox.
Ahhh right. Very wise approach
C
Old Aug 6, 2021 | 03:39 PM
DesotoJohn's Avatar
Purchased HEX-V2 & Dell Notebook!
I want to thank everyone for the input! I decided to go with the entry-level kit, since I only have two VAG vehicles at the moment. I'll upgrade as my knowledge and usage dictates. Thanks, again!
Old Aug 7, 2021 | 01:25 AM
CatmanV2's Avatar
5 Year Member
Plenty of threads and posts on line how to use it. Tread with some care. It's quite possible to break stuff, apparently!
C
Old Aug 7, 2021 | 07:39 AM
Samhain's Avatar
I think you can use it for almost all VW products - VW, Audi, Bentley, etc. I use mine on my Continental and VW Phaeton.
Despite the # limitation, you can use it to just scan as many cars as you want. Mine was very helpful in pulling codes off Continentals I was evaluating before purchase. The limitation comes in when you want to make coding changes to a car.
Shrut Amin
Bentley
Apr 6, 2022 03:24 PM
00aston
Jul 10, 2016 02:50 AM
porschelady
Jun 13, 2016 12:28 PM
chrisf1965
Jul 1, 2009 10:11 PM
JohnM
Mar 21, 2009 10:35 AM
