Infotainment issues
Infotainment issues
Hi, I have an early Continental GT, and I have been experiencing several electronic issues here and there that are really killing the B experience, since day one I have had problems with the suspension, if I leave the car for a couple of weeks parked the front end drops all the way to the ground, it should not do it but I really don't care, what is really pissing me off is the fact that once the car is turned on the front end of the car will not rise, every car with pneumatic suspension I have owned always rise by itself, but not this one, I have to manually raise it using my scanner, everything is new, struts, compressor, valve block.
Issue number 2: The AC is blowing hot air and doesn't matter how much I play with the controls it does not blow cool air, I suspect about the G17, G89 sensors which I will replace, but at this point, I'm seriously I'm considering to change my infotainment unit since it controls everything from the suspension to AC, this is not an original unit, is a BEN HUR unit, which was inoperative when I bought the vehicle, I fix a resistor in the unit, it was a simple fix and it worked again, but I have been having these gremlins haunting my car, also the steering wheel controls do not work, and my scanner reads a bunch of CAN bus errors.
Will replacing my BEN HUR unit with original infotainment may do the trick?
Thanks.
Thanks.
Were you able to fix the unit or you just installed the original unit?
I didn't repair it. It was sent back to the manufacturers
C
