Battery trickle charger
Old Oct 31, 2021 | 02:53 AM
RobBCS's Avatar
RobBCS is infamous around these parts
Hello, just purchased a supersports and I wonder what the general rule is on trickle charging is.
It has done 24,000 miles, think its been garaged, its a 2011 model and there is a connection in the boot I think.
​​​​​I think there may be two batteries - is it wise to change them both?
Old Oct 31, 2021 | 10:08 AM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
Just connect the trickle charger to the connector. Let the car sort it out
C
Old Nov 1, 2021 | 03:09 PM
RobBCS's Avatar
C
Hi Catman, it's not currently garaged so i m struggling to work out how to do this securely and in a waterproof way.
Old Nov 1, 2021 | 03:30 PM
CatmanV2's Avatar
5 Year Member
I have a 12v extension lead. The C-TEK lives in the garage and the 12v lead goes into the boot. It's perfectly happy and weatherproof if the boot is shut on the (thin) 12v cable.
This, of course, assumes you have power somewhere. If you don't, this is going to be a royal PITA for you
C
Old Nov 1, 2021 | 03:46 PM
RobBCS's Avatar
Thank you, yes I have power so I may well try that.
Where do you have your cable exit from the boot?
Old Nov 1, 2021 | 04:07 PM
CatmanV2's Avatar
5 Year Member
Just about half way between the lower left corner and the locking mechanism. Did exactly the same thing on my Maserati. Worked absolutely fine.
Although you might want to invest in one of these....
C
Old Nov 2, 2021 | 01:43 AM
RobBCS's Avatar
That looks like a good idea!
Old Nov 2, 2021 | 05:35 AM
CatmanV2's Avatar
5 Year Member
I mean what sort of idiot would forget to disconnect the C-TEK from his Maserati?
And *really* what sort of idiot would do it more than once? The same sort that was flagged down to be told there was a cable hanging from his boot, do you think?
C
John in Norcal
Dec 15, 2015 08:39 AM
boochook
Jun 7, 2013 02:02 PM
unvmy996
Sep 10, 2011 11:48 AM
showtime
Feb 14, 2011 08:44 AM
K-80
Mar 17, 2007 04:20 AM
