Do I have to change my battery?
Old Dec 19, 2021 | 04:07 AM
Pablen84's Avatar
Pablen84 is infamous around these parts
Good morning from Spain colleagues. I'm a bit worried with my GT Speed ​​because I want to take a trip around this time and I don't know if I have to change the battery in my car. I have to say that everything works, so far correctly and is continuously undergoing maintenance with ctek charger but I do not know how to interpret what the charger tells me and also I get the battery symbol on the dashboard in red, I do not know if when the battery This new one usually appears in green since I bought the car used a year ago and I never noticed.
Can you guide me or tell me something if I have to worry? I have to say that a few weeks ago I went with the same question to a workshop that fixes other cars for me and they told me that the voltage of this one appeared correctly.
Old Dec 19, 2021 | 04:55 AM
Samhain's Avatar
Samhain is infamous around these parts
Is the red battery symbol just on startup and then goes away in a few seconds? That's what mine does and seems to be normal. There is no green icon for the battery.
Here's what mine does on cold startup:
Old Dec 19, 2021 | 05:28 AM
Pablen84's Avatar
Originally Posted by Samhain
¿El símbolo rojo de la batería se está iniciando y luego desaparece en unos segundos? Eso es lo que hace el mío y parece ser normal. No hay un icono verde para la batería.
Esto es lo que el mío en el arranque en frío:
https://www.youtube.com/watch?v=3CobFuxeJuM
Oh, thank you very much!! I thought that by appearing in red it was warning me that I should change the battery. I suppose the Ctek charger would give me some kind of warning if it was wrong.
I think I remember that CatmanV2 and Darkgreen had Ctek, maybe they can know if what the charger says is all correct.
Thank you very much again.
Old Dec 19, 2021 | 07:53 AM
Samhain's Avatar
One more thing you may not know is the emergency start procedure - if the battery goes flat and will not start the car, you can join the right-hand battery to supplement the process by twisting the key all the way left, and then back right to start the car. Gives me a lot of peace of mind as these cars are finicky with batteries.
Old Dec 19, 2021 | 08:17 AM
Johnny Hotspur GT's Avatar
Administrator
Hello @Pablen84 ,
I agree as stated by Sam, the light is only red, no green, and it should go out once the engine is running.
But, what I see as far as your CTEK setting, it is wrong, you have it on "SUPPLY" as per your picture, it should be set on normal, amg/snowflake, or recond, not supply, as supply gives straight power with no variation and would cook the battery over time, supply is only used when switching out a battery if you choose to use it, or when you have a dead or no battery in place and you want to power up some minor accessories.
Johnny
Old Dec 19, 2021 | 09:01 AM
Administrator
I will add that my battery light goes out almost instantaneously as to the engine firing up, whereas Sam's stays on for about 14 seconds.
See my video at the 50 second mark.
Johnny
Old Dec 19, 2021 | 12:08 PM
Pablen84's Avatar
Thank you all very much for your response, it is very helpful.
If it is true that my red indicator on the car panel practically disappears at the moment of starting.
Regarding Ctek, as I see in the instructions I interpreted that Supply is a maintenance load, like what is usually seen in car dealerships, or that is what I intended. Have it continuously connected to the current and from time to time it just keeps itself. My battery has not been empty at any time that I know of to put it in Recond mode.
Old Dec 19, 2021 | 02:00 PM
Samhain's Avatar
My battery is about 3 years old so maybe that has something to do with the long time before it goes out. It's much shorter on hot start.
Old Dec 19, 2021 | 02:09 PM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
As long as that red light goes out after starting, it's all good. If it comes on when driving, you have a problem
For your C-Tek: Press 'Mode' until the light below AGM is lit and you'll be good. Well much better than you are now.
C
Old Dec 19, 2021 | 02:40 PM
Pablen84's Avatar
C
Thank You!! Can I have It plugged for weeks without a problem?
Old Dec 20, 2021 | 01:37 AM
CatmanV2's Avatar
5 Year Member
Can't recall when I unplugged my C-TEK last. Probably March....
C
Old Dec 20, 2021 | 02:53 AM
Pablen84's Avatar
No recuerdo cuándo desconecté mi C-TEK por última vez. Probablemente marzo ....
C
Great!!!!
leftlane
Feb 10, 2026 10:04 AM
katyrow
Sep 7, 2015 10:17 AM
jakeskiny
Jan 21, 2011 08:42 AM
ETW 360
Nov 23, 2010 05:13 PM
Dev911
Jan 27, 2005 06:52 PM
