Misfire on all left side cylinders
Old Jun 10, 2022 | 10:28 AM
2007Conti's Avatar
2007Conti is infamous around these parts
Originally Posted by Owner bentley
Hi dear
miss fire on bank 1 or bank 2 engine ecu happens because of short ground at one of the engine ecu’s , the issue is 6 cylinders has high gas pressure and misfiring and stalling and the exhaust catalyst will be hot and red so if thing happens to your car check the bank of the ecu that you have issue with , and re install one wire pin in the engine ecu that is moved from the ecu terminal.
thanks I hope that I can help .
Can you be a little more specific on which wire or pin? Also what do you mean by "moved from the ecu terminal"?
Thanks for your help
Old Jun 15, 2022 | 04:04 PM
2007Conti's Avatar
The latest on my saga is that I ordered the computer board from Poland for the EGT sensor on the driver side. Installed it and at last check, the engine light was still out with no codes.
Fingers crossed
Old Feb 8, 2023 | 09:58 AM
Owner bentley's Avatar
Owner bentley is infamous around these parts
I cannot take a photo for it at the moment because it’s fix already from before
I remembered that the wire is in a brown color at the angle for the ecu plug connector is going out al lilbit
the thing was making me more angry that when I took my 04 GT to the workshop I told him that I have one ecu wire out
he said no I should make a full check up for it then it’s shown to us that this wire iam talking about is the issue
by the way I paid about 500$ for it 🥲
P.Viby
Aug 1, 2025 12:29 PM
Baklava88
Nov 1, 2016 02:46 PM
Evolution MotorSports
996 Turbo Vendor Classifieds
15
Mar 23, 2010 02:07 PM
997 Turbo Vendor Classifieds
Dec 14, 2009 02:26 PM
Aug 19, 2007 08:57 PM
