Gap in Continental GTC roof seal: intentional?
Old Dec 8, 2023 | 09:28 AM
KCA's Avatar
KCA
KCA is infamous around these parts
I was tidying up my new (to me) 2007 GTC, and noticed that there’s a space on both sides of the car where the convertible top doesn’t seal to the body. I can see right through from the outside to the interior of the car. Is this normal? As far as I can tell, there’s no structure in the top in those sections that could hold and weather seal, so I’m assuming this is intentional for some reason. The “missing” seal is just behind the start of the panel gap between the lid for the convertible top storage space. You can see it in my photo where light comes through from inside the car underneath the closed top. Is this normal?
Old Dec 9, 2023 | 01:02 AM
xclens's Avatar
5 Year Member
xclens is infamous around these parts
Thank you for uploading a picture. That is quite an interesting discovery, and I can't imagine that it should be that way. I know that there have been issues with the metal framing of the convertible tops breaking, but for you to have it break at the same point on both sides seems very unlucky, if that's the case.
Old Dec 9, 2023 | 05:54 AM
KCA's Avatar
KCA
I'll add that after buying the car last weekend, we drove it in the rain and it sat overnight in the rain - and as far as I can tell no water made it into the car. I'll take a closer look at the mechanism today and try to figure out of there's something wrong.
Old Dec 9, 2023 | 07:38 PM
KCA's Avatar
KCA
Looking at the structure of the top, I don't see any structure to which the weather stripping would attach to seal the gap I'm seeing on both sides. Here's the gap again:
And here's how the top looks in that section:
The weather stripping just ends, and there's nothing after that = no section of the frame to provide any sort of seal against the body. It's odd, but doesn't seem to be causing any problem. The only way you'd get water in the car through there is if you spray water at that gap from the side. It would take some very high wind to blow rain in there.
I'll call the place that performed my PPI on Monday to get their take on this. They see a lot of Bentleys, so I'm assuming they'd know.
Old Dec 10, 2023 | 10:42 AM
BruceR's Avatar
5 Year Member
BruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud of
Never owned the soft top but looking at other 2007's on CarGurus it looks like a common issue.
kongolo
Bentley
May 18, 2023 04:54 AM
neiloakley
Bentley
Jan 11, 2020 08:43 PM
Hagop.oun
Bentley
Mar 13, 2019 05:21 AM
JyB
Bentley
Jul 11, 2016 05:16 AM
landsteam
Nov 13, 2015 12:46 PM
