Jack mode automatically and level fault
Old Apr 26, 2024 | 07:47 PM
ttpopo's Avatar
ttpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond repute
Originally Posted by Dgeedhar
Haha I wish I could stay under 80. I don’t think there is anything wrong with using the car in this situation? As I drove it today almost 30 miles, I kept the car in high suspension mode and there have been no error lights. When I go over 80, it just says lowering and then it lowers. It then stays good for a couple days and then the same issue occurs. Let me know your findings!
I have had my car for 700 miles and there's no issue really it seems. When i took it to my indy, there were no codes thrown by the jack mode and level fault. You see lots of issues with cars not going up.
Our problem is that they don't do DOWN reliably
Old Apr 27, 2024 | 06:25 AM
Dgeedhar's Avatar
Dgeedhar
Honestly it doesn’t really bother me to the point where I desperately want a solution. Unless it’s actually bad to drive it like that.
Old Apr 29, 2024 | 12:23 PM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
jack mode disarms the levelling system (sensors are not sensing)... you want to drive a care with air suspension which actually does not function as it supposed to?
Old Apr 29, 2024 | 05:27 PM
Dgeedhar's Avatar
Dgeedhar
The car is not in Jack mode now. It's in the high suspension mode which has been ok so far. It functions as normal I think.
Old Apr 30, 2024 | 01:00 AM
ttpopo's Avatar
if you read closely, you'll see that the issue we are having is that the car STARTS in Jack mode. It goes away when you drive off.
Sometimes we get a level fault when the suspension does not drop automatically at 80mph.
Old Apr 30, 2024 | 06:34 AM
Dgeedhar's Avatar
Dgeedhar
Yes you are correct @ttpopo . Also the car will get a level fault when you try to put it into normal mode while in high mode. Only way that worked for me was to go over 80 in high mode, and then it lowers. Sometimes it does, sometimes it doesn’t.
pupdogg
Bentley
May 8, 2023 03:45 PM
AlistairD
Bentley
Jan 19, 2023 01:18 PM
tteplitzmd
Bentley
Sep 14, 2021 08:58 AM
EJag66
Bentley
Jul 12, 2021 04:41 AM
tarnow1942
Bentley
Jan 23, 2018 03:07 PM
