Catalytic converter or O2 sensor bad?
Old Apr 17, 2024 | 09:51 AM
2007Conti's Avatar
2007Conti is infamous around these parts
Hey Guys,
My 07 Continental started running like shiite recently. Idle issues, power issues, etc. Also have been getting a gas smell when stopped at idle. Driver (left) side exhaust has soot and right side has none. Immediately thought catalytic converter and or O2 sensors. Just ran this diag and wanted to get your thoughts. I have a lift so I can remove the exhaust and check the cat. Been looking at videos of removing the cat in case worst case scenario = bad cat.
Wednesday,17,April,2024,11:33:29:03124
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: SCBCR73W47C047488 License Plate:
Mileage: 146830km-91235mi Repair Order:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCR73W47C047488 Mileage: 146830km-91235miles
Address 01: Engine Labels: 07C-906-018-BWR1.clb
Part No SW: 07C 906 018 EN HW: 07C 906 018 EC
Component: BY-6.0L-TT G ª0596
Revision: --H01--- Serial number: VWZ3Z0G7566327
Coding: 0001175
Shop #: WSC 00083 790 00000
VCID: 75B7EFC8F9D1F5E20C5-5160
VINID: 8D34938870E71074C0107108206792B95D
6 Faults Found:
001349 - Sensor 1 for Exhaust Temp Bank 1 (G235)
P0545 - 002 - Short to Ground
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146788 km
Time Indication: 0
Freeze Frame:
RPM: 1625 /min
Load: 23.9 %
Speed: 86.0 km/h
Temperature: 95.0°C
Temperature: 42.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.335 V
006420 - Pressure Sensor for Brake Boost (G294)
P1914 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 29
Reset counter: 255
Mileage: 146790 km
Time Indication: 0
Freeze Frame:
RPM: 1273 /min
Load: 11.4 %
Speed: 70.0 km/h
Temperature: 96.0°C
Temperature: 45.0°C
Voltage: 13.208 V
001287 - Idle Control System RPM
P0507 - 001 - Higher than Expected. - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 146795 km
Time Indication: 0
Freeze Frame:
RPM: 667 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 48.0°C
Voltage: 13.335 V
009571 - Turbocharger Boost Control Position Sensor Circuit
P2563 - 008 - Implausible Signal
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 979 /min
Load: 37.6 %
Speed: 2.0 km/h
Temperature: 22.0°C
Temperature: 23.0°C
Voltage: 12.827 V
001290 - Cold Start Idle Air Control System
P050A - 001 - Malfunction
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 1018 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 32.0°C
Temperature: 34.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 26.0°C
Voltage: 12.192 V
Readiness: 0010 0101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 09E 927 760 AA HW: GS1 911 4
Component: AG6 09E 6.0L W12TT 2811
Revision: 00000001 Serial number: 0101815
Coding: 0000111
VCID: 6FBBDDA09B8DCF32C69-513C
No fault code found.
Address 03: ABS Brakes Labels: 3W0-614-517-V1.lbl
Part No: 3W0 614 517 F
Component: ESP 5.7 4WD H01 0047
Coding: 0007878
Shop #: WSC 95147 000 00000
VCID: 382926FCAE43488AD73-51F2
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 E HW: 5WK 485 07
Component: 6C Kessy 6840
Revision: 68406418 Serial number: VWZ3Z0G7566327
Coding: 0405741
VCID: 290FF3B865E9E10258D-5160
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: 3W0-959-759.clb
Part No: 3W0 959 759 B
Component: CM Seat Pass. 0017
Coding: 0000002
Shop #: WSC 03251 103 57965
VCID: 48C9563CDEA3380AA73-5160
1 Fault Found:
01900 - Passengers Seat Fore / Aft Adjusting Motor (V31)
005 - No or Incorrect Basic Setting / Adaptation
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 008 E
Component: ZAB COCKPIT 2142
Coding: 0402325
VCID: 2F3B1DA05B0D8F32869-5160
1 Fault Found:
00857 - CD Changer Unit (R41)
003 - Mechanical Failure
Address 08: Auto HVAC Labels: 3W7-907-040.clb
Part No: 3W0 907 040 F
Component: Climatronic BY614 2014
Coding: 0000112
Shop #: WSC 00000 000 00000
VCID: 343112CCB22BACEAFBB-5160
3 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
014 - Defective - Intermittent
00057 - Right B-pillar/Footwell Shut-Off Flap Motor (V211)
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 H
Component: STG.Bordnetz 5101
Coding: 0000107
1 Fault Found:
00907 - Intervention load Management
000 - -
Address 11: Engine II Labels: 07C-906-018-BWR2.clb
Coding: 0001175
9 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146788 km
Time Indication: 0
Freeze Frame:
RPM: 1679 /min
Load: 22.0 %
Speed: 85.0 km/h
Temperature: 95.0°C
Temperature: 42.0°C
Voltage: 13.208 V
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146788 km
Time Indication: 0
Freeze Frame:
RPM: 1679 /min
Load: 22.0 %
Speed: 85.0 km/h
Temperature: 95.0°C
Temperature: 42.0°C
Voltage: 13.208 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146788 km
Time Indication: 0
Freeze Frame:
RPM: 1679 /min
Load: 22.0 %
Speed: 85.0 km/h
Temperature: 95.0°C
Temperature: 42.0°C
Voltage: 13.208 V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146788 km
Time Indication: 0
Freeze Frame:
RPM: 1679 /min
Load: 22.0 %
Speed: 85.0 km/h
Temperature: 95.0°C
Temperature: 42.0°C
Voltage: 13.208 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146788 km
Time Indication: 0
Freeze Frame:
RPM: 1686 /min
Load: 21.2 %
Speed: 85.0 km/h
Temperature: 94.0°C
Temperature: 42.0°C
Voltage: 13.462 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146788 km
Time Indication: 0
Freeze Frame:
RPM: 1500 /min
Load: 24.7 %
Speed: 79.0 km/h
Temperature: 94.0°C
Temperature: 41.0°C
Voltage: 13.462 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146789 km
Time Indication: 0
Freeze Frame:
RPM: 1533 /min
Load: 22.7 %
Speed: 78.0 km/h
Temperature: 94.0°C
Temperature: 41.0°C
Voltage: 13.208 V
009237 - Oxygen (Lambda) Sensor B2 S1 Voltage too Low / Air Leakage / Sample Error
P2415 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146809 km
Time Indication: 0
Freeze Frame:
RPM: 1413 /min
Load: 27.4 %
Speed: 44.0 km/h
Temperature: 93.0°C
Temperature: 62.0°C
Voltage: 13.208 V
009607 - Turbocharger Boost Control Position Sensor 2
P2587 - 008 - Implausible Signal
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 983 /min
Load: 36.8 %
Speed: 2.0 km/h
Temperature: 22.0°C
Temperature: 23.0°C
Voltage: 12.700 V
Address 15: Airbags Labels: None
Part No SW: 3W8 909 601 HW: 3W8 909 601
Component: 16 Airbag 9.41 H13 0040
Revision: 91H13004 Serial number: 0039L00057Z.
Coding: 0012598
VCID: 7BA3F9F0DFF5A3927A1-5160
Subsystem 1 - Part No: 3W7 959 339
Component: BF-Gewichtsens. H02 0004
Subsystem 2 - Serial number: 01DPR
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB4015A8B15Jÿ†63
Subsystem 5 - Serial number: A8B15Jÿ†63428RB4015A8B01Fÿ†63
Subsystem 6 - Serial number: A8B01Fÿ†63528RB4015A8688Qÿ†63
Subsystem 7 - Serial number: A8688Qÿ†63628RB4015A86EF/ÿ†63
Subsystem 8 - Serial number: A86EF/ÿ†63700RB4 Iÿ†63
Subsystem 9 - Serial number: Iÿ†63800RB4 Jÿ
Subsystem 10 - Serial number: Jÿ
1 Fault Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 16
Reset counter: 39
Time Indication: 0
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D
Component: Lenksäulenmodul 3401
Coding: 0000012
VCID: 2E0500A45C07863A8DF-5160
1 Fault Found:
01336 - Company Data Bus for Comfort System
Address 17: Instruments Labels: 3Wx-920-xxx-17.clb
Part No: 3W8 920 840 C
Component: KOMBIINSTRUMENT RB8 0610
Coding: 0023203
VCID: 3C213AEC9A7B64AA33B-5160
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9DEDC86B3D0CADF3-5160
Subsystem 1 - Part No: 6N0 909 901
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 34: Level Control Labels: 3Wx-907-553-34.clb
Part No: 3W0 907 553 B
Component: LUFTFDR.-CDC- 3C3V0 7205
Coding: 0005561
Shop #: WSC 95147 753 45725
VCID: 392F23F89549518228D-5160
1 Fault Found:
01583 - Leak in System Detected
000 - - - Intermittent
Address 36: Seat Mem. Drvr Labels: 3W0-959-759.clb
Part No: 3W0 959 760 B
Component: CM Seat Driver 0017
Coding: 0000002
Shop #: WSC 03251 103 68212
VCID: 40D94E1CF693004A6F3-5160
1 Fault Found:
00998 - Motor for Driver's Seat Recline (V45)
Address 37: Navigation Labels: None
Part No: 3W0 919 887 G
Component: NAVIGATION 2136
Coding: 0400000
VCID: 4BC36930CFD5D3128A1-5160
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 E
Component: Dachmodul 0707
Coding: 0002493
VCID: 382926FCAE43488AD73-5160
Address 46: Central Conv. Labels: 3D0-959-933.clb
Part No: 3D0 959 933 F
Component: 52 HSG 0101
Coding: 0000040
VCID: 333311D0B725ABD2E21-4B1E
Subsystem 1 - Part No: 3W8 959 701 B
Component: Tuersteuergeraet FS 1002
Subsystem 2 - Part No: 3W8 959 702 B
Component: Tuersteuergeraet BF 1002
Subsystem 3 - Part No: 3W8 959 703 B
Component: Tuersteuergeraet HL 0401
Subsystem 4 - Part No: 3W8 959 704 B
Component: Tuersteuergeraet HR 0401
Subsystem 5 - Part No: 3W0 909 610 F
Component: 14 HDSG 1809
Subsystem 6 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W8 035 456
Component: 12K-AUDIOVERST 3000
VCID: 79AFE3F8D5C9918268D-5160
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 D HW: 3W0 907 801 D
Component: EPB BC6HX24 HC6 X240
Coding: 0022401
VCID: 372B25C0A35D47F2DE9-5160
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 H
Component: Heckspoiler 0002
VCID: 30391EDC433390CA9F3-51CE
Address 65: Tire Pressure Labels: 3D0-907-273-V3.clb
Part No: 3W7 907 273
Component: Reifendruckueberw. 0003
Coding: 0480311
VCID: 7DA7F7E8C1E1ADA2445-5160
1 Fault Found:
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W1 955 023 E
Component: Wische$
Shop #: WSC 00000 725 65552
7 Faults Found:
00466 - Control Module for Steering Column Electronics (J527)
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
01308 - Control Module for Roof Electronics (J528)
00459 - Control Module for Display and Input; Front (J523)
00457 - Central Electronics Control Module / BCM (J519)
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 D
Component: Batteriemanagement 2800
VCID: 2411E28C02CB3C6A6BB-5160
Address 76: Park Assist Labels: 3W0-919-283-V1.clb
Part No: 3W0 919 283 A
Component: 02 Einparkhilfe 0303
VCID: 3B2339F09F7563923A1-5160
Address 77: Telephone Labels: None
Part No SW: 3W0 035 385 R HW: 3W0 035 385 R
Component: rSAP ECU 0054
Coding: 0000272
VCID: 44D1420CE28B1C6A4BB-5160
End----(Elapsed Time: 07:30, VBatt start/end: 12.3V/12.3V. VIgn 0.0V)------
Old Apr 17, 2024 | 12:02 PM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
Hey,
maybe this will be a great inspiration:
https://www.6speedonline.com/forums/...ying-spur.html
regarding vcds:
are we looking at re-run after all dcts erased?
Old Apr 17, 2024 | 12:08 PM
2007Conti's Avatar
No, I didn't erase and rescan. Would it help?
Old Apr 17, 2024 | 12:15 PM
sazam's Avatar
to us it will help, you will eliminate errors which are not actual so we wont bother...
just erase all,
after erasing, do the scan and save it
then do a few miles drive of the car,
and then scan again to get fresh problems if any ans save it
share both scans with us
Old Apr 17, 2024 | 01:21 PM
2007Conti's Avatar
OK, here's the new scan after deleting all DTCs and driving 6 miles. While driving the CEL would occasionally flash and then go off completely. Probably from the misfires.
Wednesday,17,April,2024,15:11:54:03124
www.Ross-Tech.com
Mileage: 146830km-91241mi Repair Order:
Coding: 0001175
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 967 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 25.0°C
Temperature: 27.0°C
Voltage: 12.954 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 931 /min
Load: 37.6 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 27.0°C
Voltage: 13.589 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 146832 km
Time Indication: 0
Freeze Frame:
RPM: 1286 /min
Load: 18.8 %
Speed: 41.0 km/h
Temperature: 41.0°C
Temperature: 27.0°C
Voltage: 13.462 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146838 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 60.0°C
Voltage: 12.319 V
Coding: 0000111
Coding: 0007878
1 Fault Found:
01312 - Powertrain Data Bus
008 - Implausible Signal - Intermittent
Coding: 0405741
Component: ELV XXXX
Coding: 0000002
1 Fault Found:
Coding: 0402325
1 Fault Found:
003 - Mechanical Failure - Intermittent
Coding: 0000112
3 Faults Found:
014 - Defective
Coding: 0000107
1 Fault Found:
000 - -
Coding: 0001175
9 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 972 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 25.0°C
Temperature: 27.0°C
Voltage: 12.954 V
P0300 - 001 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 981 /min
Load: 34.5 %
Speed: 0.0 km/h
Temperature: 25.0°C
Temperature: 27.0°C
Voltage: 12.954 V
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 1045 /min
Load: 38.4 %
Speed: 7.0 km/h
Temperature: 28.0°C
Temperature: 27.0°C
Voltage: 13.716 V
000773 - Cylinder 5
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 1045 /min
Load: 38.4 %
Speed: 7.0 km/h
Temperature: 28.0°C
Temperature: 27.0°C
Voltage: 13.716 V
000771 - Cylinder 3
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 1045 /min
Load: 38.4 %
Speed: 7.0 km/h
Temperature: 28.0°C
Temperature: 27.0°C
Voltage: 13.716 V
000774 - Cylinder 6
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 1561 /min
Load: 27.4 %
Speed: 22.0 km/h
Temperature: 33.0°C
Temperature: 27.0°C
Voltage: 13.589 V
000770 - Cylinder 2
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 1561 /min
Load: 27.4 %
Speed: 22.0 km/h
Temperature: 33.0°C
Temperature: 27.0°C
Voltage: 13.589 V
000772 - Cylinder 4
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146831 km
Time Indication: 0
Freeze Frame:
RPM: 1561 /min
Load: 27.4 %
Speed: 22.0 km/h
Temperature: 33.0°C
Temperature: 27.0°C
Voltage: 13.589 V
P2415 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146832 km
Time Indication: 0
Freeze Frame:
RPM: 1544 /min
Load: 37.2 %
Speed: 18.0 km/h
Temperature: 37.0°C
Temperature: 28.0°C
Voltage: 13.462 V
Coding: 0012598
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 39
Time Indication: 0
Coding: 0000012
1 Fault Found:
Coding: 0023203
Coding: 0000006
Coding: 0005561
1 Fault Found:
Coding: 0000002
1 Fault Found:
Coding: 0400000
Coding: 0002493
Coding: 0000040
1 Fault Found:
000 - -
Coding: 0480311
1 Fault Found:
Component: Wische$
7 Faults Found:
Coding: 0000272
End----(Elapsed Time: 07:03, VBatt start/end: 12.3V/12.3V. VIgn 0.0V)------
Old Apr 17, 2024 | 01:52 PM
sazam's Avatar
a lot of errors...
yes there is smth about o2 sensor but first i would start with inspection of vacuum lines - smoke test - because of your description of issues, and the flashing cell with misfires, and the errors around turbos...
second - you have leak in air suspension - is your car on the same level after some time sleep?
third - load management intervention sounds like issues with weak batteries or too extensive consumption - i had this one time when battery was depleted.
Old Apr 17, 2024 | 02:05 PM
2007Conti's Avatar
Went through the whole vacuum line nightmare last year and replaced a bunch of them.
Ride height is fine. No issues.
New house battery 3 months ago. Kept on a trickle charger.
Whatever the problem is, it's most likely on the left side as evidenced by the soot in the left exhaust. Also the fuel smell at idle. Right side exhaust is clean
Old Aug 12, 2024 | 02:46 PM
2007Conti's Avatar
Just did ANOTHER smoke test to verify no vacuum leaks. None. At this point, I can't just leave this car in the garage for the rest of it's life. I'll take any and all ideas
Old Aug 12, 2024 | 03:22 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Possibly (?) a failing coolant temperature sensor...the rear one. Try logging the live data on Ross T. You'll have to search on line for the address...which is universal to VW and Audi. This sensor if reading low can cause a rich condition. Same for your maf sensors. No guarantee, just a starting point.
Edit:: coolant temperature sensor reading low will cause a rich condition. Corrected in text above.
Old Aug 13, 2024 | 06:43 AM
2007Conti's Avatar
Thanks so much! I'll dive down that rabbit hole and report back what I find
Old Aug 13, 2024 | 04:19 PM
2007Conti's Avatar
Well y'all, I hate it when people on a forum really go out to help others and then when their vehicle gets fixed, they never let anyone know what the problem was.
I'm not that guy. I am however a dumbass and wouldn't even admit this but I found the problem: Blown vacuum pump fuse. I guess the moral to my story is ALWAYS start with the easiest possible fix. Huge shoutout to those who helped me with ideas, mostly Johnny and 1Eapplebaum.
Old Aug 14, 2024 | 02:00 PM
sazam's Avatar
hmm, fuse blown... why not get an error like vacuum pump open-circuit or smth...
Old Aug 14, 2024 | 02:31 PM
2007Conti's Avatar
Not sure. Doesn't show up anywhere in the above scans. If I've learned anything about this car it's that DTC codes MAY lead you in the direction of a problem and MAY NOT.
Old Aug 15, 2024 | 02:59 AM
sazam's Avatar
and your case is a great example of that...
MeNoSabe
Bentley
Oct 31, 2023 05:41 PM
xclens
Bentley
Oct 3, 2022 01:44 PM
pupdogg
Bentley
Oct 17, 2021 05:02 PM
Realdeal12
Bentley
14
Jan 26, 2021 06:14 PM
robermj1
Bentley
Feb 16, 2017 11:22 AM
