Bentley GT V8 Fuel Pump Module (Bad Ground.!!!)
Old May 18, 2025 | 01:23 PM
fastgtc's Avatar
fastgtc
Hi everybody, I’ve encountered a problem with my fuel pump module on the passenger side (right side). However I’ve found out that the problem wasn’t the module itself, but actually is a bad (smaller) ground on the connector.
When I tested grounds on the fuel pump module connector, I found out there are 2 of them. One goes on a large Pin of the connector and the other one is a much smaller pin on the connector. The lager one gives me steady readings of 11.8volts, but the smaller one bounces from 3-4-9 volts none stop (passenger side)
Just to make sure I was on the right track for my findings I took the time to test the driver’s side Fuel pump module connector and it has the same 2 grounds, and both the smaller and bigger one gives me steady readings of 11.8volts.
So I would really appreciate if anyone could shine and share with me the wiring diagram for these fuel pump modules?
I will like to know exactly where the smaller grounds come from?
However, my best guess, right away is to suspect these smaller grounds come from the ECU… But I will like to know if I’m correct before I proceed any further. I want to know if they go to some other module before they get to the ECU?? (If thats where they go)
Old May 19, 2025 | 04:19 PM
BruceR's Avatar
5 Year Member
BruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud of
What model year?
Old May 19, 2025 | 07:59 PM
fastgtc's Avatar
fastgtc
Originally Posted by BruceR
What model year?
Hey, my bad. The car is a 2014 GTC
Old May 20, 2025 | 06:42 AM
BruceR's Avatar
5 Year Member
Have a look at emanuals.com for a download.
Old May 20, 2025 | 04:13 PM
Johnny Hotspur GT's Avatar
Administrator
@fastgtc ,
For the V8.
Johnny
Old May 22, 2025 | 12:19 PM
fastgtc's Avatar
fastgtc
Thank you Johnny, I appreciate your help!👍
So I was right, straight from the ECU (from pin 91).
Now I need to find out which one is pin 91 on the ECU connector?
**But first I need to find that T8 cf connector!**
Since it looks like the wires traveling from Pin 91 to the fuel modules go to it and from there to the modules.
Also worth mentioning is that I notice there is a 19 PWM signal to the Fuel Pump Module 1 (passenger side) coming from Pin 91 on the ECU, and 73 PWM from the same Pin 91 on the ECU to the Fuel Pump Module 2 (driver’s side)
So these are my next targets:
(Perhaps Johnny you could help me?)
1-Need to find the T8 cf connector location?
2-Also need help with the specific PWM signals values?
3-Could anyone share which one is pin 91 on the ECU connector? Perhaps a ECU Pin diagram??
Old May 22, 2025 | 06:35 PM
Administrator
Hello @fastgtc ,
I think there may be some confusion here.
It is not pin 91, the "T91" stands for the connector on the engine ecu, not terminal 91, the ecu has two plugs, one with 91 pin sockets, the other 105, pin 19 that you mentioned is located in the 91 pin connector, hence the diagram depicting T91/19, just as others will be depicted as say, T105/45.
I will look to find information on that T8CF.
Johnny
Old May 22, 2025 | 09:42 PM
fastgtc's Avatar
fastgtc
You’re right Johnny. My bad. Yes the 19th pin on the T91 connector, that is what I meant.
By the way, huge thank you for your guidance and help.
So a little more progress tonight.
I unplugged the ECU from its 105 and 91 connectors and found out that the drivers side Pump’Fuel Module connector lost it’s 11.8 volt signal (from the lead wire coming from Pin 19), showing not voltage at all.
But, mean while the same lead wire on the passenger’s side Fuel Module Connector didn’t. It still showing me 3-5-4 volts!!!😳
So I wonder what other wires go to this T8 CF connector?? Because that’s probably where the problem may be?
Old May 23, 2025 | 11:57 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
@Johnny Hotspur GT ,
do you have a service software with those diagrams ? what it is and where to get?
Old May 24, 2025 | 06:28 PM
Administrator
Hello @sazam ,
What year Bentley are you needing the diagrams for ?
This link will get you the 2011 - 2014 range.
https://cardiagn.com/bentley-continental-gt-wiring-diagrams-and-component-locations-2011-2014/
Johnny
Old May 25, 2025 | 07:40 AM
sazam's Avatar
hi @Johnny Hotspur GT , mine is 2005.
Old May 25, 2025 | 01:04 PM
fastgtc's Avatar
fastgtc
@Johnny Hotspur GT
Hi Johnny, I was wondering if you had a chance to look up the proper location of this infamous T8 cf connector??
Thanks in advance!
Old May 25, 2025 | 01:28 PM
Administrator
Originally Posted by fastgtc
@Johnny Hotspur GT
Thanks in advance!
No luck yet, I will definitely let you know if I find it's location.
Johnny
Old May 31, 2025 | 04:17 PM
fastgtc's Avatar
fastgtc
Johnny
Hi Johnny by any chance do you know where this white and red wire goes to? Or comes from? I can barely read it on the diagram.
Thanks!
Ludek
Bentley
Jan 24, 2025 06:02 PM
Cervezax
Bentley
Jan 19, 2025 12:17 PM
adnanm3
Nov 22, 2023 02:43 AM
teknix999
Bentley
Jul 29, 2015 04:09 PM
BG305
Cayenne 955/957
Feb 11, 2015 07:14 AM
