Error codes p2189 - system to lean at idle, bank 2 limit exceeded
Old Jul 7, 2025 | 07:47 PM
Lawforza's Avatar
Lawforza
Recently had both Gas Exhaust Temp Sensors replaced and head gasket (as the upper half was removed) replaced. Now I get the p2189 - System to LEAN at Idle, Bank 2.(more air vs fuel) exceeding limits. See Attached Report.
Research suggests the Mass Air Flow sensor may not be seated properly, vacuum leak at intake manifold below Bentley Cover, or Air cleaner not properly seated.
Thoughts and help please. Thank you.
Old Jul 8, 2025 | 08:33 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Double check that the bank 2 valve cover breather pipe is secured where it snaps on to the valve cover. Also, verify that the breather pipe is not cracked within the outer insulation. Additionally check the air box so that it is property seated in the aluminum turbo flange below it.
Old Jul 8, 2025 | 11:45 AM
Lawforza's Avatar
Lawforza
Thank you!
I will inform my mechanic aka technician. Thank you!!
mitcho168
Bentley
18
Jul 22, 2024 10:00 AM
nickplee
Bentley
Jul 12, 2021 12:19 AM
British
Bentley
14
Apr 13, 2021 05:58 PM
SeattleTurbo
Mar 8, 2016 08:19 AM
996Tripp
Oct 17, 2012 02:37 PM
