Steering wheel vibration
Old Sep 25, 2025 | 08:23 PM
Bentleyeyesurgeon's Avatar
Bentleyeyesurgeon
I have a 2012 Bentley continental W12
It glad a steering wheel vibration that becomes steadily worse between 80k -100Km/hr
I have had numerous bently mechanics look at it and say that they can find no fault
One told me that all the second generation cars have this
Does anyone have any idea what it could be ?
Joseph
Old Sep 25, 2025 | 11:39 PM
hq_'s Avatar
hq_
5 Year Member
hq_ is infamous around these parts
Mine experienced the same exact problem. It got worse and worse until it started causing uneven wear to tires. The culprit was worn bushings. Even though the front lower control arm bushings looked perfectly fine and checked ok with a crowbar test, they had worn so soft that they deformed under load and caused vibration. I could have just installed new bushings or control arms as a package but chose to upgrade to polyurethane, which solved the problem and sharpened up the handling and steering substantially.
Old Sep 26, 2025 | 02:20 AM
Johnny Hotspur GT's Avatar
Administrator
Originally Posted by anthnino
I also experienced the same problem but I was able to solve it tho
EDIT: GOODBYE SCAMMER, Anthnino / Antinino, impersonation of another member.
Hello ​​​​​​@anthnino ,
Welcome to 6speedonline !
How were you able to solve the problem ?
Johnny
Old Sep 30, 2025 | 07:09 PM
Bentleyeyesurgeon
Thank you for suggestion
I will point this out to the mechanic
Car only has 26K on the clock though
Joseph
Old Nov 8, 2025 | 05:05 AM
EJag66's Avatar
5 Year Member
EJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud of
Mine has 44K and what seems like the same problem with a slight wrinkle: It seems to come and go. The car is perfectly smooth until approximately 60 mph, then by 65 mph the steering wheel moves visibly. Above 70 it seems to smooth out some, but never as smooth as it feels below 60. On long drives the vibration will be there, then it won't, then it will come back again. No visible issues with any of the suspension components.
Old Nov 8, 2025 | 06:21 AM
hq_'s Avatar
hq_
5 Year Member
Front wheel bearing? I replaced one of them last year after symptoms like this and now the other one is on its way out. With slight vibration at some speeds and situations. I did some elimination work and pinpointed the problem to the bearing, not the least by realizing it appears on left-hand corners, even long sweeping turns on the highway. Fortunately the bearing change is easy, approximately a one-hour job.
Old Nov 8, 2025 | 08:30 AM
EJag66's Avatar
5 Year Member
Thanks, might just do them both when I do the poly bushings.
Old Dec 30, 2025 | 02:45 AM
CUE99T's Avatar
CUE99T
Swapping to 19" Winters on OEM Wheels I found this info.
So what I realised was that I have Spigot Rings on my car for my 21" wheels, and when I take the big wheels off I get almost zero vibration on my 19inch wheels so it might be that you need to replace the rings if you have aftermarket wheels that are not 57.1mm like the hub is, and they should stick to the hub not the wheel apparently but 3 of mine came off with the wheel, so hence why I now know I have Spigot rings aka spacers on my hubs, which could be lose and probably causing the vibrations I have. Got some CNC machined ones for going on in summer.
My wheels have a 72.6mm hub so theres a gap needing filled. so I ordered these.
Spigot Rings
Just another thought.
Hutchinb
Bentley
Mar 10, 2023 09:53 PM
BruceR
Bentley
Jul 14, 2018 11:10 AM
REDNOSEGT
Bentley
Apr 29, 2013 08:15 PM
bustert
May 5, 2012 05:49 PM
