KESSY not fully functioning
Old Mar 23, 2026 | 06:25 AM
Sal-Man's Avatar
Sal-Man
Hello there, 2011 Continental Flying Spur Speed
I bought the car with this issue that the car wont unlock by touching the door handle, it would only unlock by the key fob and the car wont start by the start stop button, only with the key slot.
The car runs fine with no key warning lights.
No fault codes related to the key.
I have changed both starter and accessory batteries and still the same issue.
You can hear a clicking sound from the steering column when pressing the start engine button as shown in the video.
File Type: mov
Old Mar 23, 2026 | 01:44 PM
CUE99T's Avatar
CUE99T
Is it possible the car has a KESSY that isnt coded to your barrel and that you can start it from the barrel cos your key matches that but the car I assume must have been coded to the alarm so maybe that if its not in the KESSY is why this scenario happens? As in there is nothing wrong with the kessy, but someone lost keys, and changed the barrel and recoded a key but then again the immobiliser might not work.......not sure man.....mine causes the faults of not seeing the antennas so my start button works but my handles only open when I have cleared the faults......and I have 1 key and plan to get new keys from factory and get them to code it, and see if that maybe fixes it.
Old May 6, 2026 | 07:50 PM
DanW12's Avatar
DanW12 has much to be proud ofDanW12 has much to be proud ofDanW12 has much to be proud ofDanW12 has much to be proud ofDanW12 has much to be proud ofDanW12 has much to be proud ofDanW12 has much to be proud ofDanW12 has much to be proud of
These are exactly the same symptoms as displayed by mine when I bought it. The fix is to replace the two MOSFETs inside the KESSY module located under the footwell carpet. The procedure is widely covered on YT.
It’s likely that your drivers door handle antenna has failed too, this often leads to the above issue.
HTH.
Old May 10, 2026 | 08:46 AM
CUE99T's Avatar
CUE99T
Did you replace the button on centre console as that could be why it isnt working. I would take the centre console out and test it, or buy a used one off ebay and try a replacement.
I think you have the same problem as me. Any resolution to your door handles yet?
Pablen84
Bentley
18
Mar 24, 2026 07:33 AM
Hybrid
Oct 28, 2024 04:52 AM
CUE99T
Bentley
16
Oct 27, 2024 01:35 AM
Oli4
Jun 2, 2023 07:43 PM
ccmagic
Jun 20, 2009 12:20 AM
