BMW M3vert steering wheel vibrating at 70mph + ?
Old Sep 30, 2007 | 09:51 AM
flightposite's Avatar
flightposite is infamous around these partsflightposite is infamous around these parts
Hey guys i just got my car rims fixed cause two of them were bent. Anyways when i am driving in my car above 70mph and faster the steering wheel vibrates which i think is quite annoying. The inpsection guy at the gas station said my 19" rims were too big. Is this true cause he checked the alignment and balancing, and concluded that it was my rims that were making my car shake. Is this true for you guys with 19"s ?
Old Sep 30, 2007 | 09:59 AM
unvmy996's Avatar
that guy is a moron , u prolly lost a weight from one of ur wheels, got get it re balanced/
Old Sep 30, 2007 | 10:56 AM
will do thanks for the info
Old Sep 30, 2007 | 03:32 PM
sechsgang's Avatar
sechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant future
well, hes right about the rims being the problem but as said, its definitely a bad wheel balance...if it continues after, then the bent wheel was not fixed appropriately...
Old Oct 1, 2007 | 06:03 AM
allenjdmb's Avatar
allenjdmb is infamous around these parts
The guy at the gas station?
Gas station? 19" wheels? What's wrong with this picture?
Get to a proper whee/ tire shop. When are folks going to learn that making this stuff right is more than a matter of bolt on?
Old Oct 1, 2007 | 07:17 AM
DYL 911's Avatar
DYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to all
its either a problem with a bent rim, an unbalanced wheel, or disalignment
Old Oct 1, 2007 | 07:26 AM
allenjdmb's Avatar
Wheel alignment is dispositive to vibration....
I'll bet you an adult beverage that it's: 1. an out of round wheel, bent or other runout problem 2) an out of round tire, or other runout problem with it, or 3) a combination of the two. Doesn't anyone in your area do on car balancing? Get to a good shop!
Old Oct 1, 2007 | 10:18 AM
i got it rebalanced and i think its fine now... i did 100 and its just vibrating a little im not sure though if its because im going fast or its actually a bent rim. i think im paranoid.
Old Oct 1, 2007 | 11:01 AM
sechsgang's Avatar
no, your not paranoid...its really annoying and I am very sensative to this stuff...I would say your rim is still bent...Im going through this right now aswell...told the dealer to do ANYTHING to get it to go away as I do tons of 80 plus highway stuff and it bothers the hell out of me...
Old Oct 1, 2007 | 12:05 PM
how much does it cost u to get urs fixed? mine was like 140 per rim but the guy did it in like an hour per rim
Old Oct 1, 2007 | 12:08 PM
sechsgang's Avatar
When I had it happen it was only around 100 per rim...they turned out alright but def could have been better...
Old Oct 1, 2007 | 12:10 PM
from your dealer? wow im getting ripped off left and right fixin this car. first this then inspection failure due to too big of rims..
Old Oct 1, 2007 | 12:27 PM
sechsgang's Avatar
that inspection failier is bull****...seriously...if they are stock, you are 100 percent fine...the only rims that can incure a falier are centerlocks...which I am assuming your car doesnt have...(unless you race it on the weekends...haha) Also, dealers charge what they will based on who does the work, I dont go through a dealer for that stuff mostly (when I had bent rims, it was from 1.5 feet of air in the porsche and that was not obv taken care of by a dealership)
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
STAGGERED M3
Sep 11, 2015 12:00 AM
no1joey
Sep 2, 2015 12:32 AM
pwdrhound
Aug 20, 2015 05:54 AM
