540i project still moving on slowly,
Subscribe
Jan 25, 2008 | 05:56 PM
Reply
Jan 25, 2008 | 07:42 PM
more pics plzzz!!!!!
Reply
Jan 25, 2008 | 08:27 PM
Quote: more pics plzzz!!!!!
Reply
Jan 25, 2008 | 08:32 PM
Nice ride, what are the goals? Track car, show car or just badass daily keep us up to date on the project.
Reply
Jan 25, 2008 | 09:11 PM
Very nice!! The work thus far looks impeccable.
What other engine work was done? I've not heard.
Reply
Jan 26, 2008 | 04:41 AM
The motor , done by VAC Motorsports, Stroked to 4.75 L , Heads P&P'd , Valves 1mm over , cams done by Elgin Cams , Rods are Arrow H , Everything balanced, New timing chain & tensioner , New Vanos chains , oil pump modified , New H2o pump( Metal impeller)
Reply
Jan 26, 2008 | 08:54 AM
Quote: The motor , done by VAC Motorsports, Stroked to 4.75 L , Heads P&P'd , Valves 1mm over , cams done by Elgin Cams , Rods are Arrow H , Everything balanced, New timing chain & tensioner , New Vanos chains , oil pump modified , New H2o pump( Metal impeller)
Very nice, which crank did you use?
Reply
Jan 26, 2008 | 10:18 AM
Wow! Cool project! I'm curious to see what the final product ends up being. What sort of hp are you expecting to put down? Is this going to be a street or track car?
Reply
Jan 26, 2008 | 11:52 AM
Quote: Very nice, which crank did you use?
I am not exactly sure , An X-5 maybe? Tony had it in his shop as we tried a different way and then had to back up and use what he had that had a single chain system...... As far as HP , there is no telling. We had 440RWHP and 395RWTQ @ 7 PSI before we started this go around. A different blower , more Cubic inches , head work done , methanol injection will add up to , who knows ?It will be what it will be and we are getting closer it seems , hopefully the majority of the missing parts will arrive next week and then Nick will hopefully have the ECU mapped out for the beginning phase of a long and arduous task of re-mapping the M62's ECU....
Reply
Jan 26, 2008 | 06:20 PM
Quote: I am not exactly sure , An X-5 maybe? Tony had it in his shop as we tried a different way and then had to back up and use what he had that had a single chain system......
That was my best guess....and, IIRC, that's an Alpina sourced motor. (The 4.6is and 4.8is)
Reply
Jan 26, 2008 | 06:54 PM
Quote: That was my best guess....and, IIRC, that's an Alpina sourced motor. (The 4.6is and 4.8is)
I grew up in Charlotte eons ago.... A bunch of errors have been made on this project the shinning light are the tuners....
Reply
Jan 26, 2008 | 09:18 PM
Quote: I grew up in Charlotte eons ago.... A bunch of errors have been made on this project the shinning light are the tuners....
Very cool. Well, I must say, I admire your attention to detail during the project. Look forward to seeing it come to fruition.
Reply
Feb 18, 2008 | 12:25 PM
Just got back from ICS....
Everybody seems to be either sick or hurt so the progress has been slow as of late but , progress has been made as the new clutch and flywheel are in and the tranny is in place. The new 7" crank pulley and the new 3" super charger pulley with the new tensioner are installed. I was told all the pieces of the Aquamist HFS-5 methanol injection system are at ICS. I went out and bought the Accusump system from Canton racing products in North Branford Ct. It is a pre-oiling system for the engine. Nick G has the MAF, injectors and the ECU still and I assume that by March there will be a base line tune to see where we stand . Here are a few photos... The pulleys... The pre-oiler and reservoir tank for the methanol The intercooler and piping,the oil cooler gets the same anodized treatment The new clutch and flywheel The new crank pulley and supercharger pulley The relief that had to be cut to keep some distance away from H2O pulley That is all for now....
Reply
Feb 22, 2008 | 12:11 PM
More work being done,
Freddy came to work with a hurt ankle and is working on my car . I have been told the Tuner will have a base tune in 8 days. I bought the Laser Pro Park system along withe the Cheetah wireless system. I also bought the Bavarian Soundwerks Sub Woofer for the car
Reply
Mar 1, 2008 | 10:25 AM
A few more things added...
Freddy ran the fuel lines , the oil lines , put the Accusump ( pre -oiler) in the trunk, ran the aquamist lines, installed the aquamist pump . The oil cooler came back from being coated, The oil catch can showed up, my sub woofer showed up as well as the wireless system for the Laser Pro Park system. Nick G is still working on my ECU. Still moving forward ......
Reply
