[Vid] Modded E60 M5 vs. 996 Prot700 vs. Lotus Esprit Turbo
[Vid] Modded E60 M5 vs. HPF Stage3 M3 vs. 996 Proto700 vs. Lotus Esprit Turbo
Mexico run with friend.
-Lotus Esprit has 390rwhp and weight about 3000lbs.
-E60 M5 has 485rwhp(sprayed) and 401rwhp(all-motor) and weight 4234lbs plus one passenger.
-996TT with equivalent package to Proto700 (k24/xx) has 550+rwhp and weight 2900lbs
-E46 M3 HFP Stage3 has 700rwhp(but ran 600+ rwhp with pump gas)
Start from 2nd gear about 30mph/4-5k rpm on M5 (not smart at all). M5 didn't spray from the launch at 2nd, but sprayed from 3rd on.
http://www.youtube.com/watch?v=H-7VQLwQI3U
http://www.youtube.com/watch?v=PuVUjyCY9Vs
Note: listen carefully on the 2nd video at 0:27sec mark!!
Thanks, Juan. I'm looking forward to your project.
Most disadvantage in these races was the race started low 2nd gear and only went up to 130-140mph max. Don't know how much a passenger would affect, but unlikely change the outcome between HPF/Proto
long story short...all motor tuned make 443rwhp(basically RPI stage2), but nos tuned only make 401/485 rwhp at the moment (just dyno'd in shoot-out mode on friday, prior to that, it was 393/493rwhp).
Oh, I did not realize you changed your tune for the nitrous.
Kenny it seems to me that your nitrous is not working properly, when I had nitrous on my E46 M3, it was hit and miss at times, lol, and if the bottle is not warmed up properly it will not work. Did you have a bottle warmer on it?
I don't have bottle heater and i was running max at 780-850psi
, ideally should be 950psi. But even with 850psi, i still dyno'd at 485rwhp sprayed and it still better than my all-motor tuned for Full RPI stage2 which dyno at 443rwhp (expect about 501rwhp). Last time when it properly heated or pressure close to 950psi, I got 100rwhp more from the all-motor dyno(393/493rwhp)Even with correct psi for nitrous, it still wouldn't change the outcome between Proto/HPF
, but it might be less nasty if we start from 3rd gear roll from 70mph to 180+. It all fun regardless of the outcome for me. Who would wake up at 4:30 on sat morning
the yellow 996tts? The silver one is faster from previous mexico run, don't think they ran this time though. But this time, I think HPF stage3 slightly ahead of the Proto700.
I suspect the same but don't want to use as excuse
If I remember correctly your bottle is aluminum, so you will be able to get the pressure up pretty quickly, it will make a big difference.
....I guess I do now
