V8 z4
Old Dec 20, 2011 | 05:23 AM
mikegr's Avatar
mikegr is infamous around these parts
V8 z4
How possible is to install an E39 M5 V8 engine into a Z4?
Z4 2.2 or 2.5 has an average price of 10K. A full engine with cats and exhaust is about 8K. Get rid of 2.2 engine will save me at least 2k. So 16K for engine and car. Do you think it is possible to make this conversion with 25.000$ max?
Old Dec 21, 2011 | 08:58 AM
Twinbo's Avatar
Twinbo is infamous around these parts
You will most likely need a transmission as well.
My concern would be the electronics required to make this swap. The $$ spent on tuning alone might make this project difficult.
Perhaps try calling reputable BMW tuning shops in your area to see if this has been done before.
Old Jan 30, 2012 | 06:06 AM
mikegr's Avatar
Labor cost is to 60$ per hour so its not that bad. It should look like this
http://www.evo.co.uk/carreviews/evoc...85/bmw_z4.html
Old Jan 30, 2012 | 09:49 AM
ECS Tuning - Audi's Avatar
ECS Tuning - Audi is infamous around these parts
You'd be hard pressed to pull off an S62 swap for under 25k.
Old Jan 30, 2012 | 10:40 AM
mikegr's Avatar
well i suppose to get some cash back selling the 2.2 0r 2.5 engine. And of course looking for a used v8
I ve seen some people installing an LS2 which be cheaper probably but this must be even more hard
Old Jan 30, 2012 | 12:18 PM
Twinbo's Avatar
The LS2 swap has been done in everything from a Mazda Miata to a Jeep TJ/Wrangler. It's been documented thousands of times, and there are probably hundreds of tuners who are able to make it happen.
The S62 swap is a rare find and therefore the tuners willing to put their name on the line would be few and far between (if $ is no factor than you can make it happen).
Not trying to crush your dreams and would like to see the outcome but best find a shop first willing to give you a concrete quote on the costs.
GL
Old Jan 31, 2012 | 08:30 AM
mikegr's Avatar
that is what im doing. Looking for a reliable tuner. Then for a car and engine provider, this is the easy part.
Old Feb 4, 2012 | 12:12 PM
AvaBros's Avatar
AvaBros is infamous around these parts
Check out Rogue Engineering. I think they are working on something similar with a Z4.
Old Feb 7, 2012 | 08:41 AM
ky///m3's Avatar
ky///m3 is infamous around these parts
it has been done, some hill climb racer in germany did it
