"Transmission Failsafe Error"
Old Nov 19, 2005 | 11:55 AM
SHANKENFELTER's Avatar
SHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud of
Anyone hear of this on the new 7 series?
I'm on the highway today, and suddenly the car slows down, goes to 4000RPM and a gear icon comes on with the words "Transmission Failsafe."
3 weeks old, and time for the dealer. If this happens one more time, or if the dealer gives me a hard time in service, then BYE BYE 7. I hope this does not turn out to be a piece of **** like the 02 745.
I immediately called the dealer's service department, and the service guy said "PULL OVER IMMEDIATELY" and call a tow truck. I said Its drivable at 40mph, and its freezing here, are you out of your f*ng mind! Plus I had 1000 things i need to accomplish today.
So, any deals on Flying Spurs out there? This might be my first and last BMW. I might be overreacting, but I never had a new car breakdown....its NOT SUPPOSED to happen to new cars, IMHO!
Old Nov 19, 2005 | 12:17 PM
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
somebody told me once that "BMW" means Buy More Warranty lol
i hope you get this settled
Old Nov 19, 2005 | 12:35 PM
2thfixr's Avatar
2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold
Unfortunately Shank, that is very common for the 7 series. I am very fortunate that I have had a flawless car that has only had 2 things go wrong with it. A slow driver's door window which fixed itself and a slightly hard 1-2 shift when turning corners that a software upgrade fixed. Other guys have had endless problems with the car. Mostly 02 guys but some 03 guys. As far as 06, most guys are reporting issues with the logic 7 system, bluetooth integration issues, and some are reporting a problem with pinging and dieseling. The good news is that your problems doesn't sound like a common problem. The bad news is get used to having little problems. It's all part of the driving experience. The car still drives like no other.
Old Nov 19, 2005 | 01:26 PM
Ferrarislave's Avatar
Ferrarislave is infamous around these parts
That sucks shank, I hadn't had any problems with my 2005 5 series. A few errors with increased emissions warnings, but that was fixed with a software upgrade.
Didn't your Lambo have tranmissions failure warnings as well?
Old Nov 19, 2005 | 01:47 PM
Jeremy's Avatar
Will Party for Food!!!!
Jeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond repute
Very unfortunate, in my experience all of our BMW's were more reliable than every other brand we've had.
Bad luck with transmissions in general this month for you Shank, I'm sorry to hear that this happened.
As for flying spurs, I may have something for you, I'll check into it.
Jeremy
Old Nov 19, 2005 | 03:40 PM
Sharif's Avatar
Sharif is infamous around these parts
Sorry to hear about the trouble, that's definately not a good way to start off....
From what I've read on the roadfly board there is a transmission upgrade for the 06 7's, maybe it's related to that.
My mother's 7 has about 4800 miles on it and it's never given any trouble so far. I'm with you, if this 7 gives trouble we won't be getting any more BMW's. Mainly because of what I am going through with my m3, separating trunk floors, and it's just flat out an electronic nightmare...
Old Nov 19, 2005 | 03:45 PM
2thfixr's Avatar
Sharif,
I actually saw and responded to your post about the trunk floor. What happened with that issue? I hope you didn't let them repair that again. You should copy your post here so other people interested in M3s new or used can hear some of the nightmares that people are experiencing. That was the first time I had ever heard of anything like that.
Old Nov 19, 2005 | 03:53 PM
jamie's Avatar
Same thing is happening with the new M5's. Just drive it normally and after you shut if off the error message should go away. If not, that's why you got warranty!
Old Nov 19, 2005 | 05:46 PM
LSM's Avatar
LSM
Senior Member
LSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of light
The problems with the 7 were mainly the 2002's and some 2003's...... I am sure it is a VERY minor problem that can easily be fixed.....Good luck buddy.....
Lou
Old Nov 20, 2005 | 10:32 PM
Sharif's Avatar
Originally posted by 2thfixr
Sharif,
Good memory and timing
the car is at an excellent body shop having the whole trunk floor cut out and replaced. They are replacing the whole floor as opposed to welding cracks like last time. They are also replacing anything having to do with the rear end, shocks, bushings etc. Everything under warranty, no questions asked... The people who did the work last time didn't know what they were doing.
I let them repair it again because my lawyer advised it won't have any bearing on the case. Hopefully everything will be taken care of soon
Thanks for asking, I'll keep you updated.
Sharif
Old Nov 22, 2005 | 12:14 AM
Let us know what happens with the car Shank!
Old Nov 24, 2005 | 11:28 AM
********UPDATE**********
that day I went to my office for the day. Came back, and all the error lights went away.
Wonder what caused that.
Old Nov 24, 2005 | 12:26 PM
Paul S's Avatar
Paul S is infamous around these parts
More electronics = more problems.
Old Nov 24, 2005 | 12:47 PM
Marc's Avatar
Marc is just really niceMarc is just really niceMarc is just really niceMarc is just really niceMarc is just really nice
Yup and its not getting any better the new S class is bound to have a boatload of issues year #1 and maybe after
Old Nov 26, 2005 | 11:26 PM
zameil's Avatar
zameil is infamous around these parts
It's a common problem even with the 3 series. Turn the car off let it sit for a minute and restart it.
Happens more in the cooler months.
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
dr bit
Oct 12, 2015 09:05 AM
007 Vantage
Oct 8, 2015 08:35 PM
alpha motoring
Oct 2, 2015 12:04 PM
panas001
Sep 27, 2015 02:51 PM
