Sway bars - how much do they affect right quality?
Old Nov 28, 2006 | 01:05 PM
schnellerm3's Avatar
schnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant future
I have the Dinan Stage 3 suspension package on my E36 M3, and while the handling is great (totally flat), it's pretty uncomfortable. The stage 3 package consists of Koni dampers with H&R springs, front and rear Dinan sway cars, and camber plates. As of late I haven't been doing any aggresive driving, so I was considering removing both sway bars. Would this improve the ride quality at all, or should I just keep them on there?
Thanks!
Old Nov 28, 2006 | 01:07 PM
Gramicci101's Avatar
Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !
leave them there! Maybe swap for less aggressive sway bars, but have something there.
The swaybar is an active part of the suspension that helps to counteract body roll. With huge swaybars, the bar can actually overpower the springs and prevent any and all body roll. With no swaybars, you will notice a vast degradation of ride performance and could render your car unsafe to drive.
If your ride is uncomfortable, consider taking your stg 3 suspension down to stg 2 or 1. If regular straight driving is uncomfortable, it's the springs and shocks that are causing it.
Old Nov 29, 2006 | 01:23 AM
The sway bars aren't stock, they are Dinan aftermarket - if I remove them, the car will still handle well (it doesn't have swaybars from the factory) . Stage 1 is the same, just without the sway bars and camber plates. From what I hear, swaybars do stiffen up the ride somewhat, since they are linking the two suspension points.
Old Nov 29, 2006 | 08:43 AM
An M3 doesn't have swaybars from the factory??
Wow, you learn something new every day. Well in that case, if the car is designed around no swaybars, go ahead and take them off to see what happens.
I figured a performance-oriented vehicle like an M3 would certainly have swaybars. It never even occurred to me to check.
Old Nov 29, 2006 | 01:15 PM
Well, I assumed it didn't, the owner gave me all stock parts, and I never got any sway bars. The installation instructions also don't mention removing the stock parts. You could be right, maybe it does, I'll have to look into it.
Old Nov 29, 2006 | 01:39 PM
eshaun's Avatar
eshaun is infamous around these partseshaun is infamous around these parts
pick up a set of stock swaybars and/or look into lower spring rates
...you can probly find someone on one of the bimmer forums looking to swap....
or you could always just sell it to my buddy as is and get a nice plush daily beater for a few months Clean e36's are always in demand.
Old Nov 30, 2006 | 02:50 AM
I've been seriously considering that lately . Just can't figure out what to get that I'd enjoy...
Old Nov 30, 2006 | 08:29 AM
Just get an elise. C'mon, everyone else is doing it.
orbelo
Aug 30, 2015 12:26 PM
LiquidElephant
Aug 27, 2015 06:17 PM
TrackOne
Aug 20, 2015 12:56 PM
