View Poll Results: Which wheels for my e46 m3?
OEM ZCP (CSL wheels)
75.00%
BBS RGR
25.00%
Voters: 28. You may not vote on this poll
Which wheels?
Rating: Thread Rating: 4 votes, 5.00 average.
Old Jun 8, 2007 | 04:27 PM
  #31
PorscheC4's Avatar
PorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant future
Originally Posted by 04ImolaZHP
i believe the following to be true:
originals:
For OEM 18's: The offset is 47mm Front & 26mm Rear,
For OEM 19's: The offset is 41mm Front & 27mm Rear
dinan:
19x9.5 et45 front, 19x10 et 35 rear
Those are pretty "safe" as offsets go. You should be able to fit 275s up front with an et40 offset, and 285s rear with an et30 offset
i was also told that the ZCP wheels are the same offset.
i figured zcps were the same as oem 19s. idk ill just run spacers if needed. thanks for the info.
Old Jun 8, 2007 | 04:31 PM
  #32
InfamousD's Avatar
Formerly 04ImolaZHP
InfamousD is infamous around these parts
Old Jun 8, 2007 | 04:36 PM
  #33
InfamousD's Avatar
Formerly 04ImolaZHP
i also just saw this:
ZCP Wheels are 19" x 9.5" rear with a 27mm offset and 19" x 8" for the front with a 47mm offset.
not 100% sure which one is correct.
Old Jun 8, 2007 | 05:35 PM
  #34
StephenTi's Avatar
StephenTi is infamous around these parts
Originally Posted by PorscheC4
heres a link...
http://www.mileoneparts.com/partloca...catalogid=4462
that price is better even than what you found which i think was wrong.
HOLD UP GUYS... those are not CSL wheels. They are the Comp Coupe... 19x8.
The original post was for the CSL wheels, of which the fronts are 19x8.5... different width. I've yet to see a set of fronts remotely close to $400.
Old Jun 8, 2007 | 05:37 PM
  #35
InfamousD's Avatar
Formerly 04ImolaZHP
i am pretty sure he wanted the ZCP wheels, not necessarily the CSL.
Old Jun 8, 2007 | 05:43 PM
  #36
StephenTi's Avatar
Strange... I just checked with my BMW parts supplier... both part numbers come up as 19x8.... something is off, b/c the Euro CSL wheels are 19x8.5.
Old Jun 8, 2007 | 05:44 PM
  #37
InfamousD's Avatar
Formerly 04ImolaZHP
i am also pretty sure that the euro CSL wheels are made by bbs and possibly forged.
Old Jun 8, 2007 | 05:49 PM
  #38
StephenTi's Avatar
Here's the thing... CSL rear wheels have the same part# as the ZCP rear wheels, which we know are cast. So, unless the CSL wheels are forged fronts and cast rears, it's not likely that the fronts are forged. Ideally, I'd want CSL-sized forged wheels...
Old Jun 8, 2007 | 07:00 PM
  #39
PorscheC4's Avatar
well since you mention forged csl's, i should mention that the company that produces the CSL reps IS in fact coming out with CSL forged reps, AND Morr alloys already has then out. ive been in contact with them. they were doing group buys for 1750 and they are an aggressive offset for the e46 m3, thats another wheel we could look at imola. plus they are 19.5 lbs front and 20.8 lbs in the rear. i believe they are 19X8 front and 19X9.5 in back also.
Old Jun 8, 2007 | 07:01 PM
  #40
PorscheC4's Avatar
contrary to what was stated on the ZCP package from bmw, the CSL's or ZCP's are NOT forged.
Old Jun 8, 2007 | 07:19 PM
  #41
InfamousD's Avatar
Formerly 04ImolaZHP
i stand corrected then.
if i was to change the OEM 19's i would ideally want at least 8.5" up front. this way i can at least run 245 with some room or even 255's. 275's are probably gonna be a bit too much up front.
as far as morr alloys, their site is essentially non existant. but for a $150 more than stock zcp wheels i would say that it is probably worth getting forged. let me know how this develops. i will also have to buy some winter wheels but will most likely get some cheapies when the time comes...
Old Jun 8, 2007 | 07:33 PM
  #42
PorscheC4's Avatar
i run 245s up front on my oem 19s perfectly fine, so i dont think you need to worry about getting 8.5 inches up front. the forged csl reps are hopefully gonna be good stuff or else the ZCP wheels are fine. im almost gonna say the ZCP are better just bc they are OEM and made by BBS you know theyre good.
Old Jun 8, 2007 | 07:37 PM
  #43
InfamousD's Avatar
Formerly 04ImolaZHP
i just found some other somewhat related info:
_________________________________________
RAC Monolite RG4's are forged and made from the highest quality aluminum available. I have a set on the way for my M3. Here are some specs:
* 6061 T6 HEAT TREATED Aluminum Alloy (currently the best wheel material available)
* 8000 TON SPREAD FORGED MONOBLOCK WHEEL
* 19 x 9 Front , offset is +37
* 19 x10 Rear , offset is +25
* Wheels have a 72.6mm center hub bore so they are HUBCENTRIC (the fit is perfect, no centering rings needed)
* Can accommodate a BIG BRAKE KIT without spacers
* Powder-coated in a high quality Silver finish (brilliant)
* Can accommodate tire sizes up to a 265F/285R max.
* The RG4 wheel weights are: 22.5 lbs front and 23.0 pounds rear
* The RG4s are currently only available in fitments for the E46 M3
* Wheels will accept the OEM roundel centercap. (RG4's are designed from the factory to use the OEM E46 M3 centercap)
__________________________________________________ _
here is some more:
M67 Double Spoke Polished (OEM 19)
8 J x 19 ET47 12,6 kg (x 2.2lb/kg = 27.72 lbs)
9 1/2 J x 19 ET27 13,3 kg ( x 2.2lb/kg = 29.26 lbs)
M67 Double Spoke Crome Shadow (OEM 18)
8 J x 18 ET47 11,2 kg (x 2.2lb/kg = 24.64 lbs)
9 J x 18 ET26 12,2 kg (x 2.2lb/kg = 26.84 lbs)
M163 Cross Spoke Painted (ZCP)
8 J x 19 ET47 10,5 kg = 23.1 lbs
9 1/2 J x 19 ET27 10,9 kg = 23.98 lbs
If I had to do it again, I'd spend the extra $700 and get the real ZCP wheels.
I weighed my CSL reps, and despite the manufacturer claiming that they weigh about 25lbs, they actually weigh about 31lbs. The weight saving alone (close to 40lbs of unsprung weight since real ZCP wheels weigh about 22lbs per corner; that's like shaving 80~120lbs of weight on the car) is worth the extra $700. I was able to feel the acceleration became slower and the car didn't handle as well as before. I'm switching to the BBS RGR's. I''ll probably just keep the CSL reps and throw them on the car when I'm ready to sell the car/trade in. The reps so cheap even brand new that it's just not worth it to sell them used.
Edit: mine are the velocity motoring replica's
This is 53 pages but here it goes:
http://www.e90post.com/forums/showthread.php?t=52233
Old Jun 8, 2007 | 07:40 PM
  #44
PorscheC4's Avatar
dude! check these out, we need to get in on this sometime.
tell me those are awesome.
Old Jun 8, 2007 | 07:46 PM
  #45
InfamousD's Avatar
Formerly 04ImolaZHP
check my post above
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
