Precision Titanium Lug Bolts U.S.A.
Old Aug 5, 2013 | 08:54 AM
TiKORE's Avatar
TiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of light
Made in U.S.A.
Porsche 2-piece titanium lug bolts machined out of aerospace certified grade 5 6AL-4V titanium. Certified means each batch of material is tested to ensure the mechanical properties are correct.
2-piece design:
-allows the floating collar to seat properly on the wheel before applying final torque
-helps with any miss alignment between the wheel and the hub
-reduces the chance of marring your wheel
Pure automotive jewelry as referred to by our customers!
Matte bead blasted titanium finish.
Old Feb 3, 2014 | 10:11 AM
TiKORE's Avatar
Before: OEM steel Porsche lug bolts (corroded)
After: TiKORE titanium lug bolts installed #pureautomotivejewelry
*Titanium has an extremely high resistance for corrosion
ID:	328709   Click image for larger version
Old Feb 10, 2014 | 10:04 AM
TiKORE's Avatar
Vivid Racing + HRE Performance wheels + TiKORE titanium lug bolts.
http://store.tikore.com/porsche/
Old May 13, 2014 | 11:16 AM
TiKORE's Avatar
#WELUGWHEELS
Glad to announce both Open and Closed Ended TiKORE titanium lug nuts are available for you Porsche guys running wheel studs.
We had an inquiry for a few Porsche turbo track cars who wanted to sport open ended applications on the track but also a closed ended design on the street with their show wheels.
Designed and CNC machined in house (U.S.A.) to very strict tolerances out of aerospace certified grade 5 6AL-4V titanium.
Check out or precision Porsche products and call us today!
E-mail CFallon@tikore.com
http://store.tikore.com/993-1993-1998-911-all-models/
ID:	373974   Click image for larger version
Old Jun 11, 2014 | 02:31 PM
TiKORE's Avatar
Old Jun 16, 2014 | 12:38 PM
TiKORE's Avatar
Old Jul 1, 2014 | 10:55 AM
TiKORE's Avatar
Rotiform + TiKORE
#welugwheels by UnderWraps Automotive Porsche Cayman 981 sporting a set of Rotiform wheels bolted on by our 2-piece TiKORE titanium Porsche lugs.
Custom made with conical washers to accept lug pockets on these custom wheels.
ID:	393347   Click image for larger version
Old Jul 14, 2014 | 02:09 PM
TiKORE's Avatar
All our titanium products are custom made to order and in doing so we perfectly paired up our 2-pce titanium Porsche lug bolts with a set of MORR Wheels MS11's Contoured | Brushed Lips w/ Gloss Clear, Brushed Centers w/ Candy Black Clear, Custom Machined Porsche Center Caps.
Order a set of MORR Wheels and TiKORE titanium lugs today. E-mail CFallon@tikore.com
Old Jul 21, 2014 | 03:53 PM
TiKORE's Avatar
All our precision titanium TiKORE titanium lugs are custom made in house here at our facility. We only use aerospace certified grade 5 6L-4V titanium. Certified means each batch of material is tested to ensure the mechanical properties are correct. (not china titanium)
All lug bolt threads are rolled, not cut, for superior strength and wear resistance.
Titanium has an extremely high resistance to corrosion.
Here we have more customer submitted photos of his 911 turbo portaying why our titanium lugs are referred to as pure automotive jewelry
Product: TiKORE Titanium 2-piece Porsche lug bolt set
Wheels: RSV Forged
Vehicle: Porsche 911 Turbo
Finish: Machined titanium
Thread: M14x1.5
Seat: Ball
Shank: Standard 28mm
Head: 19mm hex
Weight per bolt: .15 lbs
*We specialize in custom lengths over OEM for those running wheel spacers. We accommodate the shank length tho the dimensions needed so you get the proper thread engagement when adding spacers.
Any questions on ordering E-mail CFallon@tikore.com
We look forward to manufacturing for your vehicles!
Old Jul 28, 2014 | 09:55 AM
TiKORE's Avatar
We always appreciate customer submitted photos, especially when they had a photo shoot done after installing the last finishing details...our TiKORE titanium lug bolts.
Vehicle: Porsche 911 C2S
Product: TiKORE Porsche 2-piece titanium lug bolt set
Wheels: Satin Bronze HRE S107s
Thread: M14x1.5
Seat: Ball
Shank Length: Standard 28mm
Finish: Bright Machined titanium
Photo Credit:
Alex Stone
702.353.4110
fotosbyalex.com
Any questions on ordering contact CFallon@tikore.com or call the TiKORE facility at 954-616-5902.
Old Aug 5, 2014 | 09:27 AM
TiKORE's Avatar
All our precision products are designed and CNC machined in house here at our TiKORE facility. We use aerospace certified grade 5 6AL-4V titanium material. By certified we mean each batch of material is tested to ensure the mechanical properties are correct. (no Chinese parts)
Old Aug 14, 2014 | 10:36 AM
TiKORE's Avatar
New wheels, no problem! Our customer got a new set of Forgeline wheels for his Porsche. The great benefit is that our TiKORE titanium lug bolts get new shoes to be sported with!
*Also remember before trading in your car equipped with TiKORE lugs to remove them and swap with OEM lug bolts. Our lugs hold their value and can be used on similar models!
Vehicle: 2014 Porsche 911 C2S
Wheels: Forgeline GT1's
Thread: M14x1.5
Seat: Ball
Photo Credit:
Alex Stone
702.353.4110
fotosbyalex.com
Old Nov 25, 2014 | 02:27 PM
TiKORE's Avatar
TiKORE titanium lug bolts vs. OEM
TiKORE Tuesday, where a local 997.1 turbo Porsche customer showed up for his install of a matte titanium 2-piece Porsche TiKORE titanium lug bolt set.
The customer had an immaculate Porsche sporting a set of HRE wheels, however that were bolted on by a set of corroded OEM lugs that physically were seized to the wheels...and had to be replaced.
http://www.tikore.com/porsche/
TiKORE machines in house out of an aerospace certified grade 5 6AL-4V titanium. Certified means each batch of material is tested to ensure the mechanical properties are correct. Each lug is manufactured individually to strict tolerances and all threads are rolled not cut for superior strength and wear-resistance.
Now for the install photos.
...and we had to take some with the TiKORE 997.1 turbo shop car
Instagram: @tikore
#welugwheels #pureautomotivejewelry #tikore #nonstopmachineshop
Old Dec 15, 2014 | 10:25 AM
TiKORE's Avatar
Check out this write up featuring Underwraps Automotive slammed Porsche 981 sitting on Rotiform wheels with TiKORE titanium lugs to bring the package together!
http://www.conduktco.com/981-reasons/
Old Jan 29, 2015 | 01:07 PM
TiKORE's Avatar
Check out the gallery put together on Flickr of all cars bolted on by TiKORE.
#WELUGWHEELS
https://www.flickr.com/photos/88463751@N05/
