LSD for 987
Old Nov 27, 2007 | 08:18 PM
dblvanos's Avatar
dblvanos is infamous around these partsdblvanos is infamous around these parts
LSD for 987
Who makes a LSD for a 05 987 non S, and cost?
Would the PSM have to be reflashed?
I hate this electronic lsd this car has,
Old Nov 28, 2007 | 10:43 AM
joelfurey's Avatar
joelfurey is infamous around these parts
I use a Stasis LSD in my Cayman. Great product and completely transforms the car. Available through Farnbacher Loles.
Old Nov 28, 2007 | 10:49 AM
dblvanos's Avatar
Is the Stasis LSD the one that is around $3500.00?
Was it worth the money?
Did you have to have the brake diff deactivated?
Old Nov 28, 2007 | 11:41 AM
joelfurey's Avatar
Yes, that's the one. Worth every penny if you do heavy track duty. If you do more street driving, you can go with the quaife TBD (not true LSD) - it gets good reviews.
You do not have to disable PSM (is that what you mean by brake diff?)
Lots of posts on this subject at www.caymanclub.net
Old Nov 30, 2007 | 08:36 AM
dblvanos's Avatar
Thanks for the link,
I don't know the technical name for it, but the system using the rear brakes to act as a sort of a limited slip.
Old Apr 25, 2008 | 04:25 PM
Mikli's Avatar
Mikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to behold
Will upgrading the LSD void the factory warranty? Sorry for the newbie question.
Old Apr 25, 2008 | 05:10 PM
tmtacq's Avatar
tmtacq is infamous around these parts
If the warranty problem can be blamed on the aftermarket part, yes. However, due to the Magnuson-Moss Warranty Act they can't void the warranty in its entirety. For example if your power window stopped working and needed a new motor they would have to cover that, unless, of course, they can attribute the window motor failure to the installation of the LSD.
Old Apr 25, 2008 | 05:28 PM
Mikli's Avatar
Which part of the car would an aftermarket quaife LSD void? I've just switch over to a 2008 Boxster S from an M3 with factory LSD. I wonder if the extra $2000 of a LSD upgarde is worth it or not for driving DE events....
Old Apr 25, 2008 | 08:38 PM
Karrera4's Avatar
Karrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to all
Even if I only drove my CS on the street the rest of its life, I would still absolutely have a TBD/LSD installed. The "electronic LSD" that keeps being brought up is just some marketing ploy that has you confused. It is simply traction control to keep one wheel from spinning under too much power. It does not in any way put that power to the other wheel which is what a TBD/LSD does.
Old Apr 26, 2008 | 07:29 PM
tmtacq's Avatar
I didn't notice you were from Canada, I have no knowledge if Magnuson-Moss exists there or how you would go about investigating it.
A LSD related warranty claim would be at the dealers discretion, I'm sure they could argue an engine failure, transmission failure, anything driveline related could be blamed on the LSD. Then again the dealer would have to know the LSD has been installed to point a finger at it.
therock88
Jul 14, 2018 11:22 PM
Mark @ AIM Performance
17
Jan 22, 2016 07:53 AM
spreeon
Sep 18, 2015 12:43 PM
Saint Ari
Sep 8, 2015 08:47 PM
