Wheel spacers again
Old Apr 30, 2008 | 08:25 AM
Tahoe M3's Avatar
Tahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really nice
Wheel spacers again
I know this has been covered before, but it seems like there's no consensus answer. What would be the correct wheel spacer size to use on a 987 Boxster S with 19" Carrera sport wheels in order to get the wheels flush with the wheelwells?
The Porsche sizes are 5 mm at all 4 corners, but the rears definitely need more than the fronts. The fronts seem ok to me but the rears need at least 7mm and maybe 14mm.
When I was at Champion last month they told me the 14mm would be too much. I can see this as being possible since the tire sticks out significantly from the wheel, so 14mm would probably get the wheel flush with the fender but might push the tire out beyond the wheelwell.
Also, the Porsche OEM kit is around $500 vs. about $200 for Eibach and $50 for H&R. Can't see why there would be such a difference since all are made of the same material.
Any recommendations?
Old Apr 30, 2008 | 08:27 AM
Karrera4's Avatar
Karrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to all
I had the 5mm spacers at all 4 corners from the factory. After lowering the car, I went with 15mm spacers (boothe design) and left the 5mm spacers in the front. Depending on how aggressive you want, you could probably go with 7mm in the front; however, I didnt want **** getting thrown up all over the car.
Old Apr 30, 2008 | 08:47 AM
Tahoe M3's Avatar
Ok thanks. And the rear tires don't stick out beyond the fenders?
Old Apr 30, 2008 | 12:23 PM
Bob Z.'s Avatar
Bob Z. is just really niceBob Z. is just really niceBob Z. is just really niceBob Z. is just really nice
Easy - measure the distance from where your tire is the edge of the wheel well lip - that will tell you how many mms you need to move them out. But if you are planning to lower it wait until you do so then measure. And was stated above, the further out you go the more crap you'll spin up onto the side of the car!
Old Apr 30, 2008 | 12:29 PM
BoxsterGirlie01's Avatar
BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !
we used 7 mm spacers on both our 986 and 996. both with 19's/offset. we got ours through wheel dynamics. you can call and ask them. they are great to work with.
Old Apr 30, 2008 | 07:31 PM
Karrera4's Avatar
Oh no, they are not sticking out at all. They really sit perfectly - not perfectly flush, but they come right to the fender.
Old Aug 27, 2011 | 02:15 PM
Carl Bastien's Avatar
Carl Bastien is infamous around these parts
Can I go 15mm without lowering the car
Old Aug 27, 2011 | 02:16 PM
wheel spacres for Carrera sports
Can I use 15mm spacers without lowering the car?
Old Aug 27, 2011 | 04:27 PM
lithium1330's Avatar
lithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud of
Yes.15mm will fill the rear wheels with the fenders. It won't do anything visually for ride height though.
Old Aug 28, 2011 | 09:57 AM
Hi Chris,
Would you have a picture of the Cayman with the Carrera sports and 15mm spacers? Does it rub at all when going through big bumps.
Old Aug 28, 2011 | 12:41 PM
Atob's Avatar
Atob is infamous around these parts
i have 7mm front, 15mm rear on my 987.2... lowered, no issues, looks great
Old Aug 28, 2011 | 01:02 PM
Do you have the Carrera Sports mags? If yes, can you send pictures
Old Aug 28, 2011 | 02:19 PM
Atob's Avatar
Old Aug 28, 2011 | 02:45 PM
These are not mounted on Carrera Sports (10 spokes) and on Cayman S. What is the offset of your wheels?
Old Aug 28, 2011 | 02:51 PM
Atob's Avatar
offset make no difference as to boxster or cayman.
i confused my rim names,,, yes, these are carrera S wheels.
good luck on you search
