Will these fit Cayman S
Old Oct 14, 2009 | 08:57 AM
RUFone's Avatar
RUFone Is a GOD !RUFone Is a GOD !RUFone Is a GOD !RUFone Is a GOD !RUFone Is a GOD !RUFone Is a GOD !RUFone Is a GOD !RUFone Is a GOD !RUFone Is a GOD !RUFone Is a GOD !RUFone Is a GOD !
Question Will these fit Cayman S
I found these wheels online at OE wheels they are a replica wheel but good for beating around. Please help with fitment on 06-07 cayman S
Will they fit yes or no?
http://www.oewheelsllc.com/Porsche-W...65026-2-1.html
thanks fellow 6speeders
Old Oct 14, 2009 | 10:48 AM
StuartsPNB's Avatar
StuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to behold
WOW! Those wheels will look good....
I say buy them.
-Nathan
Old Oct 14, 2009 | 11:01 AM
RUFone's Avatar
Thinking about it, i want to powder coat them mat black.
Old Oct 14, 2009 | 03:31 PM
Johnny Danger's Avatar
Awaiting Email Confirmation
Johnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to behold
Before you purchase any wheel set, you should carefully calculate the difference in fitment in order to make sure that you will have proper clearance.
Old Oct 14, 2009 | 05:19 PM
ag_boxster's Avatar
ag_boxster is infamous around these partsag_boxster is infamous around these parts
Before buying I would check the rear offset, the info I've found states the fronts are right at 50mm offset, but the info I have says the rears should also be 50mm not 65mm. Make sure they are right, or find out what the return policy is and remember that shipping them back can be expensive not to mention that they will not refund your ship to receive cost either.
Old Oct 14, 2009 | 07:11 PM
If I am not mistaken the oem wheels on your Cayman are the following sizes and offsets : 18x8 +57 offset and 18x9.5 +43 offset. If that is the case, the rear wheels will retract in 16 mm and you will loose 28mm of inner clearance. That would be disastrous !
Old Oct 14, 2009 | 08:38 PM
KelvinC's Avatar
KelvinC is infamous around these parts
Also, check with the CaymanClub folk. There were a few threads of a company called Raderwerks I believe that made an 18" version of the turbo wheel exactly like that in specific Cayman fitments. The price I think was pretty good too.
Old Oct 15, 2009 | 05:50 AM
rubber_ducky's Avatar
rubber_ducky is infamous around these parts
$10k marked down to $500. Looks like a screaming bargain.
Old Oct 15, 2009 | 06:50 AM
RUFone's Avatar
Thanks for all the response.
Its a great deal for a set of rims to beat up on. I think i will probably need spacers for the back. Do you guys have any idea of tire size? 265 or 305's
Have a good day!
Old Oct 15, 2009 | 05:47 PM
tom kerr's Avatar
Have a good day!
I run 255 front 305 rear
Old Oct 15, 2009 | 08:46 PM
Fluid987's Avatar
Fluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond repute
tom kerr
Tom Isnt that a little big? I have 245 fronts and 295 Rears with 8mm rear spacers and it looks pretty maxed out IMO
I couldnt Imagine 255's and 305's
Has anyone Done this ? Thanks
2lflat4
Nov 18, 2019 05:05 PM
PelicanParts.com
Aug 25, 2015 03:35 PM
Mar48
Aug 24, 2015 01:13 PM
Jakk55
Aug 20, 2015 05:47 AM
PelicanParts.com
Aug 18, 2015 03:49 PM
