boxster timing belt
Old Dec 6, 2009 | 05:30 AM
damon's Avatar
damon is infamous around these parts
boxster timing belt
can anyone tell me how often the timing belt on the 986 should be changed? ive got the 1999 model with 70,000 miles on the clock and it has never been changed. should i think about changing it?
Old Dec 6, 2009 | 07:30 AM
sid's Avatar
sid
sid is a glorious beacon of lightsid is a glorious beacon of lightsid is a glorious beacon of lightsid is a glorious beacon of lightsid is a glorious beacon of lightsid is a glorious beacon of light
Boxster does not have a timing belt.
Old Dec 6, 2009 | 07:31 AM
jjanari's Avatar
jjanari is infamous around these parts
you don't have a timing belt; you have a timing chain. while the belts, which are basically rubber, require changing at certain intervals, the chains, which are metal, don't typically require changing.
do you have a service manual? it should tell you when your major services are due.
Old Dec 6, 2009 | 11:18 AM
damon's Avatar
Thanks for your help guys!
i was looking at a pic of a boxster engie and it showed a rubber belt and i thouht it was the timing belt!
so no need changing of the chain then? cant find anything on the manual!
Old Dec 7, 2009 | 09:17 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
Nope, barring something catastrophic you should never have to touch the chain.
Old Dec 15, 2009 | 06:50 PM
ppbon's Avatar
ppbon is infamous around these parts
But the poly-ribbed belt should be replaced every 60,000 miles.
Happy Boxstering,
Pedro
Old Dec 16, 2009 | 11:47 AM
damon's Avatar
oh, thats what i saw then, the poly ribbed belt. i have 70,000 miles on the clock, then its time i changed it! what is its purpose exactly?
Old Dec 16, 2009 | 11:55 AM
dekebabamoto's Avatar
dekebabamoto is infamous around these parts
Damon:
Some p-car guys advised me to keep the belt you remove as an emergency spare in case something happens while you're on a nice, weekend cruise in wine country.
Old Dec 16, 2009 | 01:45 PM
ppbon's Avatar
The purpose of the poly-ribbed belt is to drive the A/C, the alternator, the water pump and the power steering pump.
If it breaks while the engine is running, all you won't have cooling, air conditioning or battery charging and the steering will get VERY heavy.
It's good to keep the belt you're replacing as a spare.
Happy Boxstering,
Pedro
2lflat4
Nov 18, 2019 05:05 PM
PelicanParts.com
Aug 20, 2015 02:45 PM
Aug 20, 2015 12:17 PM
