Plasti-Dipped Rear
Plasti-Dipped Rear
Decided to paint the lower back of my car black. Before selling my Corvette a few of the Corvette owners were experimenting with the Plasti Dip so I decided to join the crowd. I painted the bottom back of my rear bumper. I plan on doing the side vents, mirrors and spears.
Before:
After:
Before:
After:
Symmetry, did I not center the car in the picture enough for you?
It's plasti-dip, the metal around the exhaust would get too hot which could cause the plasti-dip to bubble up. If you notice the lines, the exhaust metal piece is higher than the lines of the bottom rear. If I do the metal piece it will be higher than the original line, causing the symmetry to be lost.
All I did was recreate the carbon fiber layovers. Even the TA Rear Diffuser doesn't cover the metal.
If you look on the right side on the bottom spear, a little from the right you will see a where it's a bit ruff.
Looks nice. I'm always amused by those of us that modify cars. If its body color, paint it black. If its black, paint it body color. If its amber, make it clear. If its clear, make it smoked. If the car has 5 spokes from the factory, install LMs. If it came with LMs, put on 5 spoke.
Ok, enough, I've got work to do.
Jim
Jim
Jim
Jim
cheers
I did test spray on some parts I have laying around and I was able to add a clear coat after waiting a day for the plasti dip to dry...and remove the plasti dip after hours of drying but it was difficult in some areas. Next test is adding paint on top of it!
I think the peeling happens when the tape isn't peeled fast enough. If you don't pull the tape, after spraying, fast enough it rubberizes and you pull the smallest part up but it causes an issue long term. In reality it's not good to have too good of a tape job. I actually pulled up a few spots because I taped into the cracks and it pulled up the dip a little bit when I pulled the tape.
So my findings with the Plasti Dip and clear coat continues. After learning how to fix paint chips, I figured why not try to sand off the plasti dip with 1500 grit sand paper...and I found success with it. I just plasti dipped my side vents and decided to test this out on the back of the piece. It comes right off and the paint still looks great. These pics are right after I started to sand away.
Now I'm going to go ahead and clear coat the piece. I'll post pics...
I painted the silver exhaust surround trim in black - used the Krylon Fusion for Plastic in black. I basically masked the surround trim (without removing them from bumper) with painter tape and also wrapped the exhaust tips. No sanding or prep. This paint has been holding up like new for past year - even after a few track events.
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
