Ecu
Old Apr 15, 2012 | 09:28 PM
Crocodile's Avatar
Crocodile is infamous around these parts
Ecu
Hello, I have never modified any of my vehicles so forgive my ignorance with my question:
Can I modify my 2007 2.7L Cayman via ECU only and nothing else? What can I expect. Has anyone done this and would care to share their experiences?
Old Apr 16, 2012 | 01:14 PM
harryrcb's Avatar
harryrcb is infamous around these parts
Yes you can, check out this site http://www.softronic.us/buynow.php . Having said that, it would give you more benefit a lot more if with the dme tune you also went with a cold air intake system and better exhaust.
Old Apr 17, 2012 | 01:29 PM
ECS Tuning - Porsche's Avatar
Yes, there are "Stage 1" tunes available for bone stock cars than don't require any type of aftermarket hardware modification. You can make power out of a non-force induction motor, but the gains arn't as spectacular as a turbo or supercharged application. You may see a 5-10 horsepower increase. That being said, an aftermarket intake and an aftermarket exhaust will add power.
Old May 1, 2012 | 07:28 AM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
PM sent....
Old May 1, 2012 | 08:32 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
You can but you are limited. My opinion is that if you're going to to modifications to your engine/tuning you should get air in, then get air out then tune. You're expense is half or over half way there if you're going to update your ECU. You can change your intake and exhaust relatively cheaply then tune and you may see double the results afterwards.
Old May 2, 2012 | 12:12 PM
dinorocz's Avatar
not much of a difference in NA cars for air in/ air out (as you mentioned) mods.
Old May 2, 2012 | 12:46 PM
sales@ECU Tuning Group's Avatar
sales@ECU Tuning Group is just really nicesales@ECU Tuning Group is just really nicesales@ECU Tuning Group is just really nicesales@ECU Tuning Group is just really nicesales@ECU Tuning Group is just really nice
We achieve 18hp 16lbs tq with only an ECU tune. Contact us for more details.
Old May 2, 2012 | 02:52 PM
thstone's Avatar
thstone is infamous around these parts
The stock ECU is fairly well tuned. Not usually much to be gained unless you are making other mod's that significantly increase airflow.
Old May 3, 2012 | 09:13 AM
dinorocz's Avatar
this is not true at all... Installed softronic tune on a customers Cay S and the changes were significant.
Followed that up 2 weeks later with a fabpseed Race exhaust and even more improvement, plus the benefit of weight reduction.
Oct 2, 2015 02:23 PM
