Removing/Installing aluminum thrust bushing in the rear control arms
Old Jun 23, 2012 | 07:09 AM
Little Gator's Avatar
Little Gator is infamous around these parts
I want to replace the soft rubber thrust arm bushings in my Cayman's rear/lower control arms with some solid aluminum ones. Is it possible to do this without removing the control arm from the car? It looks like it might be if I remove the the bolt that connects the angular link to it. Will there then be enough movement in the angular link that I can swing it out of the way so I can attach a threaded draw bar to pull the rubber bushing straight out the bottom of the control arm?
Old Jun 23, 2012 | 09:28 AM
StockKiller's Avatar
StockKiller is infamous around these parts
Goto to the tech stuff tab..
There's a link for 997 DIY .. Lots of links there.. Your info might be tucked in there..
Jul 29, 2019 11:13 AM
COBB Tuning
Nov 9, 2015 08:02 PM
orbelo
Aug 30, 2015 12:26 PM
VGLNTE1
Aug 20, 2015 08:14 PM
TrackOne
Aug 20, 2015 12:56 PM
