Boxster brake pedal sticks
Old Aug 19, 2012 | 06:22 PM
cmoore1's Avatar
cmoore1 is infamous around these parts
The brake pedal on my '99 Boxster doesn't immediately return after applying the brakes--after a second or 2 the brakes release and the pedal returns to normal. Any ideas?
Old Aug 20, 2012 | 10:35 AM
extanker's Avatar
extanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond repute
you could check the pedal linkage but it sounds like the booster if all the brakes release
Old Aug 21, 2012 | 06:08 PM
cmoore1's Avatar
Now it's gotten to the point where the brakes don't release without a foot under the pedal to raise the pedal back to normal height. Would this have anything to do with the "vacuum brake line"?--this was replaced 2200 miles ago.
Old Aug 22, 2012 | 05:43 AM
extanker's Avatar
what is the brake repair history on this car...in detail please...it may help in advise
Old Aug 22, 2012 | 11:44 AM
cmoore1's Avatar
Brake repair history: 9/30/2010 3111 miles ago---4 rotors + pads. 12/28/10 2177 miles ago vacuum brake line replaced--this was done at the same time as an IMS retrofit, tiptronic trans exchange,rms seal, oil separator--no brake problem was reported at this time--shop decided to replace the vacuum brake line because it appeared to be near the end of life.
The problem seemed to get worse after I had the brake system flushed a few days ago as part of a 4 tire replacement. I had the brakes flushed after I noticed that the brake replacement job back in 2010 didn't list any brake fluid charge on the list of materials used.
I would take it back to the shop that did the 2 previous repairs but I now live 625 miles away. Eventually I guess I'll have to trailer it to Reno--2hours away--I believe this is the nearest place with either a dealer or indy shops. The car also needs a rear alignment (the tire shop that replaced the tires & flushed the brakes couldn't do it). Rear alignment necessary because 2 new Pirelli PZero Nero's wore out after only 2600 miles--the right more than the left (the car was aligned , or I paid for an alignment at least, 500 miles before).
Old Aug 22, 2012 | 01:46 PM
extanker's Avatar
with this additional info i would check the master cylinder first then the booster. imo. they did use the right fluid ?
Old Aug 23, 2012 | 07:58 PM
the_vetman's Avatar
the_vetman has a spectacular aura aboutthe_vetman has a spectacular aura about
Check for major air bubbles in the brake system.
Old Aug 29, 2012 | 11:34 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
I would certainly have it inspected instead of talking about it here. You have a vehicle that's 13 years old and has had brake work done. Something wasn't done or done correctly so I would get it fixed before you drive it any more.
audipwr1
Sep 25, 2021 01:31 PM
2lflat4
Nov 18, 2019 05:05 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
