Boxster S smokin tailpipe problem
Old May 3, 2006 | 04:50 PM
ppickerell's Avatar
ppickerell is infamous around these parts
My wife's Boxster S smokes out the tailpipe for 10 seconds after cold start. The dealer says this is normal. What do you all think?
Old May 3, 2006 | 09:28 PM
mbodo's Avatar
mbodo is infamous around these parts
I usually smoke right before I go to bed. Doctor says this is normal.
(putting hand to forehead) ... IIRC, my '94 SHO had this problem, and it was .... piston rings??? I honestly forget, but somehow oil was seeping past somewhere where it shouldn't seep past, and once the car warmed up and parts expanded into place, everything was fine.
Try posting this on renntech, or just wait for Toolpants to come back around here. I think Toolpants is a Boxster.
Old May 4, 2006 | 04:10 PM
Brad Roberts's Avatar
Brad Roberts is infamous around these parts
Patrick,
Is it smoke or steam? They all steam out the tail pipe until the cats warm up.
I doubt seriously it is smoke. You'll know when the Air/Oil seperator fails (it will smoke continously when cold)
B
Old May 4, 2006 | 04:38 PM
doclaw64's Avatar
doclaw64 is infamous around these parts
It is normal. The Boxster will sometimes smoke on start up. If it lasts a long time then something is wrong but if it is just a few seconds after start up it is fine.
Old May 5, 2006 | 07:54 PM
ppickerell's Avatar
Smoke
Originally Posted by Brad Roberts
Patrick,
B
Brad,
It is smoke. And not the good kine.
Old May 8, 2006 | 12:54 AM
ross's Avatar
Awaiting Email Confirmation
ross is infamous around these parts
All porsches puff black smoke out when they start up after sitting for awhile. A small amount of leftover oil in the valve cover drains down the valve guide and past the seats and into the cylinders. Its normal.
Old May 8, 2006 | 07:02 AM
jnx's Avatar
jnx
jnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to behold
Sounds normal to me.
Old May 9, 2006 | 07:57 PM
Um.. Ross...
Porsche has used valve stem seals to control oil flow back into the valves since 1990 (if not earlier)
Old May 13, 2006 | 11:55 AM
ross's Avatar
Um.. Ross...
correct, but they still leak
Old May 15, 2006 | 10:00 PM
Dave's Avatar
Dave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to behold
Mine does the same thing. The turbo, however, does not?!....hmmm....
Socalsporty
Sep 9, 2015 10:07 AM
arhim22
Sep 7, 2015 08:49 PM
the997dude
Sep 2, 2015 08:51 PM
