Loaner Boxster roof/window question
Old Jul 30, 2006 | 12:31 PM
Zmann's Avatar
Zmann is infamous around these parts
My car is in for a service and they gave me an '06 Boxster. I can't get the windows to close completely when I put the top up. They open about 2" when the top is closing. The window buttons then remain operable only in the down mode. Push them back up and they stop at the same position.
Is there a trick or is there a problem. Might rain here today......
BTW, miss my 993, but this thing is a blast to drive - though the base model could use more horses.
Old Jul 30, 2006 | 12:35 PM
ShimShimHada's Avatar
ShimShimHada is infamous around these parts
Did you lock the top down with that lever thing? Try opening and closing the doors again.
Old Jul 30, 2006 | 12:43 PM
Zmann's Avatar
Yep. Locked that lever. Tried that a couple of times.
Will try the doors.
Old Jul 31, 2006 | 02:31 PM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
Sounds like you need to reset the windows.
With the top up and after restarting the car put the windows up all the way and hold the switch in the up position for at least 5 seconds.
Old Aug 8, 2006 | 12:05 PM
WillisW555's Avatar
WillisW555 is infamous around these parts
That happens to me sometimes. If I put the top up, but shut the car off before latching the top, the windows don't go up. I usually just turn the car on and then latch the top again and it's fine.
Periokid - No more SLK32 huh? I remember you from the MB websites a few years back.
Old Aug 8, 2006 | 10:05 PM
Periokid's Avatar
Willis,
Yup, no more slks. But my website lives!!
Old Sep 14, 2006 | 04:47 PM
MuffinMan's Avatar
MuffinMan is infamous around these parts
Did you ever get this solved? Sometimes the lever/switch goes bad on the latch that holds the roof close. I believe you can test it by holding a switch down with your finger instead of with the latch.
2lflat4
Nov 18, 2019 05:05 PM
Gus_Smedstad
Aug 29, 2015 04:43 PM
pogeybait
Aug 28, 2015 04:47 PM
Aug 20, 2015 12:17 PM
Jakk55
Aug 20, 2015 05:47 AM
