Anyone changed oil on a Cayman?
Old Sep 9, 2007 | 09:04 AM
adeeois's Avatar
adeeois is infamous around these parts
Has anyone changed oil and filter on your Cayman? Any significant problems due to the mid engine design? I'm planning a change soon and don't necessarily want to pay dealer prices. I will be using Mobil 1. What oil weight are you using?
Old Sep 9, 2007 | 11:24 AM
MSCaymanS's Avatar
MSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud of
Yes it's very easy. There is a DIY on caymanclub. As far as weight I use the 0-40w that the manual recommends. They also have the torque specs ofr the filter and drain bolt on caymanclub. I've done mine at 5k,10k, and getting ready to do it again at 20k.
Old Sep 12, 2007 | 11:55 AM
adeeois's Avatar
Thanks for the heads up on the Cayman club site. Looks like a pretty straight up job. I was mostly concerned about the oil filter location from changing my 996TT (top rear of engine). Cayman filter looks to be very accessable. Takes the same cartrage as the 996TT.
Old Sep 21, 2007 | 09:32 PM
dyazdani's Avatar
dyazdani is infamous around these parts
I've done it on a Boxster, seems similarly located. No issues with access, in fact, if you have long arms you can reach it without getting under the car. My biggest issue was the tool to get the filter housing off. I originally bought the "6 in 1" tool as shown on the Pelican Parts DIY, it did not work, the plastic cracked immediately. I went back and got a metal removal tool, after that the whole process was a snap.
Good luck.
SharkyShark20
Sep 19, 2015 09:54 PM
Sales@RSW
Sep 3, 2015 09:34 AM
00aston
Aug 27, 2015 12:01 AM
Aug 20, 2015 12:17 PM
