Convertible top hack; Disable speed and handbrake overrides??
Old Sep 26, 2007 | 02:07 AM
PK2's Avatar
PK2
PK2 is infamous around these parts
Hello,
I’d like to do 2 things with my top.
1, Disable the speed restriction for operating the top.
2, I’d like to disable the handbrake requirement (I’m just not that lame).
Surely someone’s done a hack like that,. Anybody know of a thread? Or done it? (I’ve searched allover, I can't be the om;y one and it can’t be that complicated)
Thanks, PK
P.S. I'm familar with a ciouple of plug in mods tha do all this + have a "one touch open close" funtionality, nice but rather pricy...Exact same logic as my garage door opener...
Old Sep 26, 2007 | 06:53 AM
bill930p's Avatar
bill930p is infamous around these parts
I did it on my old Boxster. You have to pull the conv. top relay. Find the pin that is labelled as 18. Just gently bend it over and plug the relay back.
This disables the speedo input. You still have to engage the hanbrake, but one click up should work. At low speeds this won't be an issue.
Some cars require two clicks of the handbrake for the switch to activate. This can be adjusted if need be.
Remember, don't drive over 20 mph while operating the top. Could cause serious damage.
Old Sep 26, 2007 | 11:29 AM
PK2's Avatar
PK2
Thanks allot, that’s a start. I’ve heard abut bending this “pinâ€. By bending this pin, am I bending it to touch something else or keep it from touching something? Where is position of pin 18 denoted?
Seems like it wouldn’t be a big trick to jump (and therefore disable) the e-brake part. All I’d really like to do is coast into a parking spot while the tops going up.
Thanks a lot for the tip
Regard, P.K.
Old Sep 26, 2007 | 11:47 AM
bill930p's Avatar
You are bending the pin to keep it from making connection. The pins should be labeled on the relay.
I don't know if you want to jump the e-brake. The light would always stay on in the dash. With the ebake up one click you can still coast as the brake isn't engaged at the wheel. I used to do this all the time.
Old Sep 26, 2007 | 12:33 PM
djomlas's Avatar
djomlas is infamous around these parts
yeah pin 18 is easy, just pull it out and bend it away.
Old Sep 26, 2007 | 03:54 PM
Gary in BR's Avatar
Gary in BR is infamous around these parts
I have had it done on my 99 since 2000, great hack, and well worth the 3 minutes to do it.
In my opinion keep the hand brake in the mix, that way my 9 year old at the time cant activate the top going 60 because he was cold. Now that he is 13 he wants the top down all the time because its cool.
Old Sep 26, 2007 | 06:50 PM
bill930p's Avatar
Gary, Your car looks great. How reliable has it been with all those miles.
I got rid of mine when the warrantee expired. I was thinking of getting another as a daily car.
Old Sep 26, 2007 | 07:06 PM
blinkwatt's Avatar
blinkwatt is infamous around these parts
I've always wondered if the 1st click of the handbrake even engages the handbrake. It seems to do nothing until you hit the 3rd-4th clicks.
Old Sep 27, 2007 | 08:15 AM
bill930p's Avatar
Thats partially right. It does contract the brake from the first click, however, it takes a few clicks before the pad makes contact.
Old Sep 28, 2007 | 01:07 AM
PK2's Avatar
PK2
You’ve pretty much got to really wrench on my e brake to get the light on (probably adjustable). Maybe just disconnect the light along with whatever other mod. I hardly ever use my hand brake and when I do, I sure know it’s on as soon as I let the clutch out.
Thanks. Another wrinkle to pursue
PK
Old Sep 28, 2007 | 01:12 AM
PK2's Avatar
PK2
Are we talking the double sized relay/controler in the drivers footwell above the fuses? Mines got a circut board inside with 2 little tinney relays on it.
Thanks, PK
Old May 27, 2018 | 02:31 PM
Leonardo111's Avatar
Leonardo111 is infamous around these parts
Video Tutorial
Heres a good video on how to do this:
COBB Tuning
Mar 29, 2016 09:26 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
The Oss
Aug 24, 2015 08:19 PM
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
Walorus
Aug 18, 2015 01:39 PM
