Need Wheel Help!
Old May 12, 2004 | 01:59 AM
renntech36's Avatar
renntech36 is infamous around these partsrenntech36 is infamous around these parts
Need Wheel Help!
If I were to get a set of wheels for my Cayenne Turbo, and they are 22x10, would I want a +41mm offset or a +60 offset.
Also, I will be doing Michelin Diamaris tires, and would I like to have your opinion on something; on the 22x10, should I run a
265/35/22 up front and a 285/35/22 in the back, or should I do 285/35/22 all the way around? Thank you so much. By the way, here are the wheels, just insert Porsche center cap!:
Old May 12, 2004 | 05:07 AM
Wheel Experts's Avatar
the Cayenne is AWD, id use the same size front and rear
if the rim is a 10" use a 295/30/22
Old May 12, 2004 | 05:38 AM
renntech36's Avatar
thanks peter !
I dont know if you remember me, but I used to be on BNZSPORT and also repped a red coupe. It had the red RENNTech wheels on it, so you and I were alike rockin the red 2 door benzes! Anyways, thanks for your help, and I may be PMing you about some prices on some 21" and 22" wheels you have at your store.
Harris Snodgrass
-Brumos Porsche-
Old May 12, 2004 | 06:36 AM
of course I knew it was you harris - thats why I responded to your question so quickly
Old May 12, 2004 | 07:51 AM
DEETZ's Avatar
GO 6SPEED!
DEETZ is infamous around these parts
Peter is the best, he knows everything about wheels I agree with him 295/30/22 and 22x10.0. Pirelli and Conti make that size
Old May 12, 2004 | 09:03 PM
renntech36's Avatar
i definetely agree with that deetz! anyways, peter thanks for the help. I will keep you up to date with what I do! Also, can you ship wheels because one of my good friends is picking up either an 04 M3 or an 04 S4 in the next week or so, and he wants to do immediate HRE's! I will definetely try to send him to you and hopefully I may be able to get some wheels from ya!
THanks
Harris Snodgrass
-Brumos Porsche-
Old May 13, 2004 | 02:06 AM
damon@tirerack's Avatar
Moderator
I agree that the 265 is the best to use if doing so all around. 285 should work in back, just keep in mind the AT Italia wheel is only availablein 10" wide, so the front tire profile is different than will be in the rear. I'd stay 265 all around for the best appearance. Give me a call if you need to discuss it any further or order, x.643.
Old May 13, 2004 | 02:31 AM
Moderator
By the way, a standard Porsche crest wont fit into the center assembly unless you modify it to fit. Just wanted to let you know.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old May 13, 2004 | 05:03 AM
renntech36's Avatar
thanks for your help Damon!
I saw on your website where it said 265's were optimal, but I think that is just not enough meat! I have 275's on the truck now, and I think it just needs a little more! Would either 285-35-22 or 295-30-22 rub all the way around? Thanks for your help.
Old May 14, 2004 | 03:34 AM
Moderator
The 285 is rather short and not really recommended unless the gross axle rating is above 3750 lbs. It barely holds enough air to properly support the truck's weight. 295 hold more air, but we have never tested that size on the truck. If the other guys here have used it without problems than it will fit the 10" wide rim. One thing that concerns me is tramlining with such a wide tire. A 295 is really wide for the front and may grab and follow ruts in the road.
damon@tirerack.com
Or use this link:
Zero911
Aug 24, 2015 06:51 PM
Aug 21, 2015 09:56 AM
ModBargains
Aug 20, 2015 12:28 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
