Best way to lower an 08 Cayenne S?
Old Oct 8, 2007 | 05:19 PM
brettcp's Avatar
brettcp is infamous around these parts
I'm looking to upgrade from my stock 18's to some 20's or 22's.. but want to reduce some of the wheel well gap when i do so..
Ride comfort/quality is important - so what's the best method to lower it just a bit? I don't have the air suspension.
Thanks!
-Brett
Old Oct 8, 2007 | 05:43 PM
sleekmotoring's Avatar
sleekmotoring is infamous around these parts
I would lower it using adjujustable links. Easy to install. Plus you dont have to mess with any electrical.
Adjustable Air Ride
Old Oct 8, 2007 | 06:56 PM
brettcp's Avatar
Adjustable Air Ride
Ok, but I don't have air suspension.. will those adjustable links still work?
Old Oct 8, 2007 | 09:13 PM
SoCal955's Avatar
SoCal955 is infamous around these parts
No, The best ride will be provided by installing coilovers. They will also give you a lower ride vs springs.
Old Oct 9, 2007 | 12:45 AM
brettcp's Avatar
which coilovers?
Old Oct 9, 2007 | 02:25 AM
hendrady's Avatar
hendrady is infamous around these parts
kw coilovers
Kw coilovers work best!
Here's an example of a cayenne (w/o air suspension) using KW coilovers..
they are adjustable anytime, but you'll have to adjust them manually.
However, there's always a cheaper way: Techart/H&R springs will work too.
Old Oct 9, 2007 | 08:46 AM
GoldenPEPPA's Avatar
GoldenPEPPA is infamous around these parts
wow! looks awesome. How was the ride? Better/Worse than lowering springs?
Old Oct 9, 2007 | 10:43 AM
Dwn2Race's Avatar
Dwn2Race is infamous around these parts
what size rinspeed are those?
Old Oct 9, 2007 | 03:21 PM
hendrady's Avatar
The ride's not too bad, best for only 1 pessenger =p
if you often have people sitting at the back, dont bother!
haha.. gives you much more stability and control..
and looks wayy cooler too.
Old Oct 9, 2007 | 03:22 PM
hendrady's Avatar
The Rinspeeds are 23"
dgreen78
Feb 29, 2016 11:28 PM
Yellopeter
Cayenne
Oct 9, 2015 11:20 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
