Tire Pressure System question
Old Dec 26, 2007 | 02:11 PM
h2woo's Avatar
h2woo is infamous around these parts
For those of you with aftermarket wheels, did you need to purchase Porsche tire pressure sensors for the wheels to make it compatible?
I have an '08 and just trying to cover all bases before I decide on a set of rims.
Regards,
Rich
Old Dec 26, 2007 | 06:20 PM
Griza's Avatar
Griza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud of
You could probably use the ones in your stock wheels if you are not going to use them again. I had to purchase new TPMS since I am using my stockers for winter. I got them from suncoast I think for like $350.
Old Dec 27, 2007 | 04:21 PM
h2woo's Avatar
griza, once they are mounted is there any sort of configuration that needs to be performed or does the vehicle recognize the new sensors?
Old Dec 28, 2007 | 05:54 AM
Griza's Avatar
I had to go into the menu and check off which size tires I was using. Then as I was driving the psi went blank and I got a warning symbol. I guess this was when it was configuring the new sensors. I continued driving a few more miles and everything registered and it has been perfect ever since.
Old Dec 28, 2007 | 06:01 AM
invncble's Avatar
invncble is infamous around these parts
If you just remove the TPMS and upgrade to new wheels does the warning just stay on the dash?
Old Dec 28, 2007 | 07:19 AM
Cpa4S's Avatar
Cpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to behold
h2woo - is that your red boxter?
looks like it has the sport design package.
Old Dec 28, 2007 | 09:24 AM
h2woo's Avatar
thanks for the heads up griza.
cpa4s - pretty close, that is actually the 3400S Ruf kit - which is essentially a GT3 with shortened rocker panels to fit the boxster. The sport design package is very similar except the rocker panels are not as pronounced.
Old Dec 28, 2007 | 12:27 PM
wheels's Avatar
wheels is infamous around these parts
My Cayenne Turbo S came with 20" wheels. I mounted winter tires on the stock 20" wheels and left the TPMS in them. I purchased Techart 22" wheels for summer. I purchased 22" tires and TPMS from Tire Rack. The TPMS from
Tire Rack work fine with the Porsche system. Only issue is the menu only goes up to 20" wheels. I just use the 20" setting and make sure the pressure is where I want it.
Old Dec 28, 2007 | 12:57 PM
Griza's Avatar
That is exactly what I did...
Old Dec 28, 2007 | 01:02 PM
damon@tirerack's Avatar
Moderator
Careful, some wheels are not made to accept the new sensors. Make sure you ask before buying them. All of what we carry for the 997 will take the new sensors.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
The Oss
Aug 24, 2015 08:19 PM
