Fog Lamps Error Out?
Old Mar 14, 2008 | 06:11 AM
mlc.design's Avatar
mlc.design is infamous around these parts
Cool Fog Lamps Error Out?
Hello All
I just changed my Fog lamps on my caycay to the HID they work perfectly but after a few minutes (3) of them being on the system faults me out saying check fog lamps...a buddy of mine used the same kit on his cayenne same year and all no issues.
Ideas?
Thoughts?
Standard bulbs are fine once added in a Ballast for HIDs error started
MLC
Old Mar 14, 2008 | 06:26 PM
canberk's Avatar
canberk is infamous around these parts
You'll need to have some resistors on their power cables in order for the system checking to think that the fogs are normal. Consult your dealer regarding this issue, they'll help you
Old Mar 15, 2008 | 08:27 AM
mlc.design's Avatar
What do i say when contacting them?
Old Mar 15, 2008 | 08:33 AM
canberk's Avatar
Tell them that you've replaced your fog lamps with xenon ones and your car is throwing an alarm message after a while, which is a result of a failure in the system check. Tell them that this can be remedied by adding the required resistors in the middle. They should understand it before you explain the situation actually. It's all about tricking the computer to not to check your fog lamps. Since the xenons work differently than regular fogs...
Old Mar 16, 2008 | 07:48 AM
mlc.design's Avatar
ok sunset is probably the place to calll yes?
Old Mar 16, 2008 | 09:51 AM
canberk's Avatar
not for me from Michigan
Old Mar 16, 2008 | 05:18 PM
mlc.design's Avatar
Haha
do you know what ohm is needed? just call a dealer?
Old Mar 16, 2008 | 06:09 PM
2008cayenne's Avatar
2008cayenne is infamous around these parts
Originally Posted by mlc.design
Haha
I came across this website and it seems that this might solve your problem (for some strange reason they decided to call this a "BMW Harness"):
http://www.gthid.ca/
At http://www.launchtec.ca/forum/viewtopic.php?t=10, they explain the following:
Q: I have a newer vehicle with automatic headlights, or a BMW, will GT HID work with my vehicle?
A: Yes, GT HID is one of the few companies that have special harnesses for vehicles with automatic headlights, you can contact us to order these harnesses.
Advanced: Example a 2004 Chev truck, has automatically activated headlights with a daylight sensor on the dash board. The computer that controls the headlights detects the factory headlamp as a 65w-85w light bulb, if the resistance is less than that of a normal light bulb they computer will turn them off to avoid any problems. GT HID only requires 35w to operate, which is outside of the computers safe zone, and may turn them off. We have designed a special wiring harness that will trick the computer and still activate the HID light at the same time, so your vehicle will think that there is a halogen bulb in it and nothing is wrong.
Old Mar 16, 2008 | 06:53 PM
mlc.design's Avatar
Thanks 2008 Cayenne
But do they sell the the harness seperate?
I will have to look?
Old Mar 16, 2008 | 08:17 PM
I would call/email them and ask. Also, try this guy:
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=009
Old Mar 17, 2008 | 09:26 AM
mlc.design's Avatar
so i checked with a few dealers they never heard of using resistors for the error codes...any ideas what to do?
or what resistor to use?
Old Mar 18, 2008 | 01:38 PM
gmoney's Avatar
The car is looking for a 55w bulb and your only drawing 35w through it with the HID system and it throws the bulb out warning.
I would not go the resistor route, they generate tons of heat and unless mounted correctly they can burn things they touch or are mounted too.
http://www.superbrightleds.com/pdfs/...istor_info.pdf
Might be wiser to pull the HID kit and simply install xenon look bulbs from Hoen, PIAA etc.
Old Mar 18, 2008 | 02:21 PM
SLP's Avatar
SLP
SLP is infamous around these parts
i agree, thats probably your best route. i put in HID look fogs...i think they look great.
Old Mar 19, 2008 | 05:28 AM
mlc.design's Avatar
SLP
are yours just bulbs or full HID with Ballasts?
MLC
Old Mar 19, 2008 | 06:33 AM
SLP's Avatar
SLP
just the bulbs MLC...looks great compared to the stock bulbs...and without all the issues of modifying wiring, etc.
